I'll take a set
I'll take a set
Modification ThreadOriginal Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)European Auto Source TechInstagram: @CarbonZHP
I'll take a pair 👍🏿
2004 330i ZHP Imola/Alcantara 6MT
Installed them today and everything went pretty smoothly. I clipped wire ties on both sides of the car to make it easier to maneuver. And on the washer fluid side I just removed the screw and then pulled the reservoir up and back a bit, holding it in place with tape. Love the look! And they have to be safer with all that output.
Thanks!
iPhone/Tapatalk Pro
Other tweaks: see my profile
Very nice.
I forgot to mention that the bulbs are polar, so be sure to test them before you go through the struggle of reinstallation. If one doesn't work, pull it out and flip it around.
Guessing you didn't run into this or have worked with LED bulbs before.
3 sets left after today
The brown wire is negative. Yes-definitely used to LEDs
iPhone/Tapatalk Pro
Pm sent
Sent from my SM-G930F using Tapatalk
2007 BMW Z4 M Coupe | Interlagous Blue | Maritime dash and console trim | 6MT
UUC short shifter, Euro cats, CSL Euro headers, Evolve CSL Intake and tune, TC Klein Smart Design Double Adjustable Coilovers, Dinan strut brace, CDV Delete, ZHP shift knob, Arkym splitter and spoiler, WPC Bearings, ARP rod bolts, Apex Arc-8, VAC Pump Upgrade, Bluebus
Seems like mine aren't working? Both leds tested on both sides in both polarities
Well that's concerning. The only thing that made them not work in my testing was when I adjusted the PWM values too low. Now that I think about it, they stopped working completely when that happened, even after I reset the values/error codes. I believe I had to turn off the car, reinstall the incandescent bulbs, cycle them a bit, then go back to the LED's. Actually, I'm pretty sure this happened with some cheap-o LEDs and not the nice ones.
Sorry for the rambling. Try replacing with incandescent and reinstalling?
Standard bulbs work fine. Haven't done any pa soft work yet. Would that stop them working completely?
