Results 1 to 3 of 3
    Sep 2014
    Mountain View, CA
    Driver's side mirror - memory issue / position issue?
    I've done some Googling but can't seem to find a thread that mirrors (pun intended) my issue.
    1) I set my mirror at the desired position, set memory.
    2) I found that my mirrors were a bit off for some reason, pressed 1 to get it back to the memory position. It only moves for a second or two and stops, moving nowhere near my set memory position.
    3) Tested it by moving the mirror towards the cabin away from the my ideal position and pressed 1. Mirror starts to move towards the cabin, away from the direction it should be going.
    However the motor has full range of motion, controls work perfectly.
    Has anyone experienced this?
    Is there a reset procedure for setting the limit like the windows?
    Jun 2014
    Toronto, ON
    If you have PA Soft, pull the codes. There are potentiometers built into the mirror motors which report the X/Y position back to the GM5 module. Sometimes these potentiometers go bad and that is when you experience things like these.
    I have similar issues with my passenger side mirror motor. You should see a similar error under the ZKE module:
    "50/39 - Passenger mirror: Potentiometer axel 2/4"
    anandoc
    Sep 2014
    Mountain View, CA
    Quote Originally Posted by anandoc View Post
    Thanks! I'll take a look and replace if necessary.
  1. FS: Driver-side memory mirror
    By alexandre in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 06-25-2016, 10:09 AM
  2. WTB: Driver's side mirror
    By anandoc in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 07-19-2015, 04:00 AM
  3. WTB Driver (left) side door side mirror (sedan)
    By gammagoblin in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 03-16-2015, 08:29 AM
  4. Auto-Dimming Compass Mirror Retrofit Issue
    By TomTomTuning in forum General -- ZHP Related
    Last Post: 08-23-2013, 04:43 PM
  5. Window Regulator Issue....Not the normal zip tie fixable issue
    By 328ioc in forum Mechanical | Troubleshooting
    Last Post: 04-19-2012, 05:59 AM
