Results 1 to 10 of 14
    Beaverton, OR
    What brake fluid are you guys using?
    I thought I had some on the shelf, but looks like I used it. Need to bleed em this weekend. As long as it's DOT 4, does it really matter? I don't track, simple DD.
    I think this is what I used before
    https://www.ecstuning.com/b-ate-part...liter/sl6~ate/
    However the OEM fluid seems like a better deal, I can't imagine it really takes three of these for a flush...
    https://www.ecstuning.com/b-genuine-...l/81220142156/
    2016 BMW M340i
    2013 BMW X5 M-Sport - Sold
    2009 550i M-Sport - Sold
    2006 650i Vert - Sold
    2004 330i ZHP - Dead
    2001 330i Sport - Sold
    2004 330i ZHP - Sold
    1999 E36 M3 - Sold
    Jun 2012
    Socal
    Yeah it doesn't really matter. It takes 3 of the OE ones because it's 355 mL per bottle. Usually they come in like 500 mL or like 1 L bottles for other brands.
    Aug 2014
    Leesburg, VA
    I used the BMW fluid last time as the local BMW club chapter had a DIY tech session at the local dealer so I purchased the fluid there. I typically use Valvoline DOT 3 and 4 Synthetic Brake Fluid as it's reasonably priced, readily available so I don't worry about compatibility & works for me.
    VA/DC
    The blue can.
    Beaverton, OR
    Right on, thanks fellas!
    2016 BMW M340i
    1999 E36 M3 - Sold
    What about the DOT 4 LV (low viscosity) Bentley says to use in the e46?
    Sent from my ONEPLUS 3 using Tapatalk
    Sep 2011
    San Francisco, CA
    The blue can.
    Same as you!
    I've been using Pentosin DOT4 LV. Might switch.
    Using ATE Typ200 because I do about 2-3 track events per year so I need higher boiling point temp fluid.
  1. Brake Fluid Chart
    By derbo in forum Brakes
    Last Post: 06-26-2016, 12:55 PM
  2. How does this brake fluid look?
    By stephenkirsh in forum Brakes
    Last Post: 03-29-2014, 05:22 PM
  3. What brake fluid do you use?
    By ryankokesh in forum Maintenance
    Last Post: 09-26-2013, 10:07 AM
  4. QUESTION: Brake Fluid
    By Stigissimo in forum Maintenance
    Last Post: 06-19-2013, 11:13 AM
  5. ATE brake fluid in San Diego
    By blablac in forum California
    Last Post: 11-23-2011, 05:37 PM
