Hey Gents,
Been chasing a weird one in my 2004 ZHP lately. She's a garage queen, and very well kept. I was about an hour into a three hour drive when at about 60MPH the engine completely shut down. Triwd to restart and it will crank & crank (like. a bad fuel pump, which is operating normally). When this happened, temp gauge went from normal to pegged, and car would not restart until about 15 mins later when something reset and temp gauge came back to where it should be. Turned around and drove the hour or so home with the car doing the same thing - randomly shutting down while driving, unable to restart for a period of time. Probably happened 12 times over the next hour. I have been searching thr web trying to read about possible problems, but have not seen anything concrete except that this seems to be pointing to a DME problem.
Here's what I know:
Car is not running hot or overheating. Fuel pump is working perfectly. Swapped the battery just to see if it was a low-power issue, and it made no difference. No dash lights on normally, yet I would get some sometimes after this happens until it resets, then occasionally thereafter a few would stay on until I restart. Engine grounds and battery terminals are all tight - even tried a hard reset disconnecting the battery for a period before reinstalling. Car will run flawlessly up to temperature and usually beyond, then it will randomly shut off. This happens under load or sitting at idle not moving. Ironically never sets a check engine light, but scans reveal CAN BUS errors.
So any ideas Mafiosos? Think I am on the right track pointing to a bad DME/ECU? Thanks in advance for your collective wisdom & experience.
Here are a few pics. Temp needle pegged is after shutdown. Next is after sitting when I can restart it.
