Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 56
  1. #21
    May 2014
    Milwaukee, WI
    Was the sunroof seal a pain? It only took one sunroof leak in the X3 (albeit from the drains, not the seal) to have me a little paranoid about things like this.
    Overall it probably only took me an hour to do. The glass is held on by only 6 T25 screws that are all easily accessible from inside the cabin. Once you get the glass off, removing the seal is pretty easy, there is not adhesive or anything, just a rubber grove that the seal "snaps" into. Getting the new one on proved to be harder, as getting it to "snap" in all the way around took a good amount of finger power and a small flat head screwdriver to push it in and "lock it"..
    Once you get it back on the tricky part is making sure the glass is level with the roof, so its helpful to have someone outside the car checking if its level before you tighten the screws inside. Have not tried pouring water on it yet, but will do soon to test. There are no gaps or anything and the fit looks just as good as my non-leaking seal before it. Except this one doesn't have dried wax, bird droppings, and 12 yrs of age and crustiness...
    - Dave in WI, USA -
    '05 330i ZHP 6MT IMOLAROT
    /LEDERSCHWARZ
    ALSO CURRENT: '13 X5M Monte Carlo Blue
    PAST: '16 340i 6MT | '13 328i AT | '05 330i ZHP 6MT Mystic Blue | '06 330ci ZHP 6MT Imola Red
    HERS: '19 X3 xDrive40i Blue
  2. #22
    May 2014
    Milwaukee, WI
    New headlight lenses and euro fronts installed tonight! Much much better
    - Dave in WI, USA -
    /LEDERSCHWARZ
  3. #23
    Jun 2014
    Toronto, ON
    Looking great! Are these OEM euro sidemarkers? Which bulbs are you using?
    Some pics of the sunroof seal DIY would be great (location of the T25 torx screws etc).
    anandoc
  4. #24
    May 2014
    Milwaukee, WI
    Yes, these are the OEM Euro lights from Turner. The bulbs I have are LED Cree Canbus: http://r.ebay.com/zcwk2f. No flicker at startup or bulb out notifications.
    I will take some more pics on the Sunroof later tonight
    - Dave in WI, USA -
    /LEDERSCHWARZ
  5. #25
    VA/DC
    Quote Originally Posted by dlucas589 View Post
    Need this badly. Part number handy? Vas, let's get together and do this.
  6. #26
    Thumbs up. I want to do it as well on sketchi
    Sent from my SAMSUNG-SM-G920A using Tapatalk
  7. #27
    Looks amazing. Please provide sun roof seal part number.
    Sent from my S8+
  8. #28
    May 2014
    Milwaukee, WI
    P/n: 54138218001
    https://www.ecstuning.com/b-genuine-...l/54138218001/
    3 Torx screws on each side
    - Dave in WI, USA -
    /LEDERSCHWARZ
  9. #29
    VA/DC
  10. #30
    May 2014
    Milwaukee, WI
    Finished up the RCR setup tonight...
    Kept the stock bulbs in the bottom row of red running lights, put LEDs in turn signals, red brakes on top, and white reverse.
    They flicker on startup, which I will need to code off in PA...just need to find the software around here somewhere. When I sold my last E46 I kept the OBD cord...I knew I'd be back.
    - Dave in WI, USA -
    /LEDERSCHWARZ
  1. Replies: 60
    Last Post: 10-04-2021, 12:09 PM
  2. Replies: 290
    Last Post: 10-03-2019, 08:29 AM
  3. Replies: 594
  4. Replies: 769
  5. FinanceGuy's Maintenance/Project thread -- 08 E70
