Results 11 to 20 of 27
Thread: Rust Advice ZHP
    VA/DC
    Quote Originally Posted by A1Gio2 View Post
    I am unable for the life of me to upload a pic on this site. I've tried every way. Is there a posting amount restriction?
    If I email it to someone can they post it for me?
    You tried going "advanced" and using the paper clip? Use Tapatalk on your phone and upload that way?
Size:  350.0 KBName:  IMG_0625.JPG
    Looks like Tapatalk will do the trick. I'm posting the images of the rust for reference. Couldn't find any other areas of rust around the car. Also posting a pic of the overall condition of the car, which I consider to be very good.
    Based on those images have the rust fixed.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Kensington, Maryland
    Yeah just have it fixed man. The sooner the better.
    When I first bought my car I noticed a rust bubble inside the passenger door sill - Right where the door closes and the water gathers? Someone must have nicked the paint there just hard enough to allow moisture to get in. Took it to a body shop down the street who stripped the paint, removed the rust and resprayed it. No one is the wiser and my car is safe.
    Ask around for a good body shop if you don't have one. I have a great mechanic in Maryland who I trust.
    ~Rob~
    Oct 2016
    Frankfurt, Germany
    Definitely get it fixed. Doesn't look too bad.
    Here's a scary one from Germany to motivate you!
    May 2016
    Chicago, IL
    On the topic.. what's your guys' opinion on this?
    Starting to develop on the crown on the underside of the hood
    Bimmerworld Stage II Clutch with Kevlar Disc and JB Racing Lightweight Flywheel(Retired)
    Hotchkis Sport sway bar | ECS Tuning Carbon Fiber front strut braces | performance throttle body
    Michelin PSS | Blizzak WS-80
    Quote Originally Posted by Prestovie View Post
    That can be cleaned up and touched up.
    Dec 2016
    Greensboro, NC
    +1. Check the top of that lip (behind the grilles) also. I had flaked paint and rust in the same spot as you. I personally just masked it off, sprayed it with rust converter, and then a coat of rubberized undercoat to keep water from getting back to it. I did that to a spot on the bootlid too. Given the location, and knowing it's in a place where literally no one will ever look, I was much more concerned about function than aesthetics.
    M3 Dead Pedal | M3 Front Seats | Lexus ES300 Yellow Fog Light Retrofit | Koni Yellows/H&R Springs | Llumar CTX 40% | Coby Tri-Stitch Wheel & Boots
    May 2016
    Chicago, IL
    I'll try and get to it this coming weekend, thanks for the input. It's not seen often so I'll go same route with function over aesthetics
    I ended up having mine repaired.
  1. Upgrade advice needed
    By RedAtom in forum General -- ZHP Related
    Last Post: 04-21-2017, 05:17 PM
  2. Car Crisis Situation: Help/Advice Needed ASAP!!!
    By webster in forum General -- ZHP Related
    Last Post: 01-26-2013, 05:10 AM
  3. Watkins Glen Advice Needed
    By az3579 in forum Track and AutoX
    Last Post: 05-10-2012, 03:11 AM
  4. Advice Needed ....
    By elric in forum Suspension
    Last Post: 03-06-2012, 07:12 PM
