Results 1 to 7 of 7
    Help with Part #s
    The 3 screws (and the associated metal clips that they thread into) that go up through the very front of the splash guard into the front bumper are missing on my car. These 3 track the curvature of the front bumper, they aren't the ones that go down the sides or back of the splash guard.
    Does any one the part numbers for the screws and the clips?
    I'm not 100% sure, but I believe they're as follows:
    Screw: 07147177492
    Securing clip: 51717195796
    You can check the diagram here: http://www.realoem.com/bmw/enUS/show...74#51718268344
    Aug 2014
    Leesburg, VA
    The plastic expanding rivet (#20) works on the sedan, but is more of a pain to remove when you need to drop the splash pan.
    http://www.realoem.com/bmw/enUS/show...diagId=51_4519
    Charleston SC
    Those aren't screws and clips on the sedan they are the plastic rivets. If you look closely, you'll see why
    H&R sport springs,
    So the screws/clips run along the sides and back of the splash guard, while the plastic rivets are used up front?
    May explain why those 3 plastic rivets have fallen out over the years...
    Charleston SC
    Help with Part #s
    Yes that is correct
    There's nothing special about those plastic rivets , you can just get them at a place like AutoZone
    H&R sport springs,
    Aug 2014
    Leesburg, VA
    Quote Originally Posted by nsk040 View Post
    Probably left off during an oil or fluid change that required the splash pan to be removed.
  1. Replies: 25
    Last Post: 02-04-2014, 08:50 AM
  2. 06' ZHP part out
    By MooseX in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 05-16-2013, 08:38 AM
  3. E46 Part Out....
    By das boots in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 01-15-2013, 08:32 AM
  4. Need help finding part number or part
    By bullfrogs_M3 in forum General -- ZHP Related
    Last Post: 08-25-2011, 12:37 PM
