I topped up the washer fluid by adding about half a gallon. 5 minutes later when I parked the car I noticed a decent amount fluid leaking out of the car (guessing ~20oz in terms of volume). 90% of the volume was dripping out the bottom of the car directly under the driver's headlight, the other 10% was dripping out couple feet further back of that. Fluid is pretty clear, not much smell, and hot enough to hurt if you catch more than a a few drops in your hand. Let car sit for ~15 mins and the drip basically stopped. As soon as I started the car up, the drip resumed. No lights on the dash. Based on the volume lost, I don't think it's washer fluid as that reservoir appears to be at the level I filled it to.
I'm assuming I'll drop it off at the shop that's only a mile down the road in the morning provided no further loss of fluid over night.
Hopefully this is enough info for a accurate diagnosis! Thanks
