Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Jan 2011
    Martinez, CA
    I just replaced the PS reservoir and the 4 hoses. It totally pissed me off when I came to a dead stop since I needed the special tool to remove the hoses. I think they are available at Autozone. But I bought mine at FCP. Pretty quick shipping and inexpensive.
    It made ALL the difference in the world. You do have to finagle the thing on there, but once you do, you just pull the hose back. Once it stops, remove the tool and the hose comes off the rest of the way.
    In my case, the PS fluid was leaking into the alternator and giving me a red battery warning light. So, I also swapped out the alternator while I was in there. Same with the PS pump. Not hard to do at all.
    Palm Beach County, FL
    Ok so we went under and found the leak not much from the reservoir or the hoses, but from the entry to the CV joint area as you see from my friend pointing at it under the rubber cover/(boot?):
    Name:  ZHP - Steering Leak - 01b.jpg
    So he was wondering what is the least amount of work we can do to fix this... do we need to replace the whole CV joint and the center arm? Or is that part of the piston ram seal, or....
    Last invoice the shop gave me they said I also need the control arms replaced, SMFH... I dont think that has anything to do with this but just letting you know, because I dont know, and dont want to leave any info out. They already supposed to have replaced the bushings, not sure how they did not see that then, but that may be a whole another story.
    Hankook Ventus V12
    Front: 225/45ZR
    That's just a tie rod and boot. You could just replace the boot, but a set of tie rods isn't a bad idea. If the steering rack is leaking out the side and into that boot, then you probably need a new rack.
    Quote Originally Posted by Smolck View Post
    So all that is pretty easy to do as well?
    Sent from my Nexus 6P using Tapatalk
    Hankook Ventus V12
    Front: 225/45ZR
    Yep. I'd replace the tie rod and boot first and keep an eye on it (tie rod has to come off to replace the boot, so replace it because most people destroy them removing the outer tie rod joint). Even if you have to replace the rack its held to the subframe by 2 bolts, there are 2 lines connected to it, and remove the two tie rods and it comes right out. Very easy.
    Check out my BMW Blog
    Follow me on twitter @smolck
    Great info all!
    Dec 2017
    Lake Wylie, NC
    The same guy you linked to 50sKid also has one where he replaces the tie rods.
    https://www.youtube.com/watch?v=75Qt_O5x2M0
    I like that guy's videos. He has one where he keeps spilling coolant. It happened so many times, by the end, I was just rolling on the floor.
    I'm going to be replacing tie rods next weekend unless something comes up. I tried to do a quick steering wheel alignment before taking it into to have it aligned, and my outer tie rods were seized. Grasping the tire at 9 and 3 o'clock and rocking it had some play and clunking, so mine needed to be done.
    FCP Euro has a little better price than ECS, and amazingly they will warrant the tie rods for life. Hard to believe they do that on wear items, but they do.
    I went with Lemforder, since they are the OE mfg. Same thing, cheaper price.
    Left Lemforder 32106777503
    Right Lemforder 32106777504
    BMW Steering Rack Bellow Kit - Febi 32131096910 (Need a CV boot crimping tool or some other rigged way of crimping the clamp. Some people use zip ties. You need two of these if doing both sides.)
    I didn't have one, so I ordered a tie rod puller and an offset CV boot crimping tool.
    http://a.co/fZ7DmB8
    http://a.co/3suHSRC
    That puller linked to above is probably of low quality, but should do the job. A handy hint I saw one guy mention that I thought was a good idea is to use the puller and get it under a lot of tension, but don't keep cranking down on it until it pops off violently. Instead, he got it under a lot of tension, then gave the tie rod knuckle a couple of light taps with a hammer, and it popped loose very nicely.
    Salty
    Bone stock at the moment
    Yes, that's a good way to loosen any tapered bolts that have almost seized in their tapered pockets. A good sized brass drift to whack on will keep you from dinging the surrounding metal. By the way, last month I was checking some cars at the local Pic n Save (You-pull-em) and found a 330 that someone must have spent some suspension/brake bucks on. Some of the parts had been pulled already, but it had pretty fresh Meyle HD control arms, tie rods, and a nice aftermarket sway bar (haven't measured it yet.) Figured somewhere down the road I might need them, or could sell them to someone who did, and bought them all for under $100. The control arms even have nice 50/50 bushings. Danged if an alignment job on my car a week and a half later didn't reveal worn outer ball joints. It took most of a Saturday to do the swap - a bear to remove the inner ball joint nuts, but was well worth it. The car drives super now and I'm curious to see how my new Cooper Zeons do over time - so far they feel terrific.
  1. Tricky problem with windshield washer fluid leak
    By dpark in forum Mechanical | Troubleshooting
    Last Post: 01-09-2018, 04:01 PM
  2. Help with fluid leak diagnosis
    By nsk040 in forum Mechanical | Troubleshooting
    Last Post: 09-24-2017, 03:31 PM
  3. Power Steering Fluid Explosion?
    By downshift in forum Mechanical | Troubleshooting
    Last Post: 05-22-2017, 01:51 PM
  4. Power Steering Hose Leak
    By TigerTater in forum General -- ZHP Related
    Last Post: 03-24-2015, 04:56 PM
  5. Cringeworthy, help- oil in power steering fluid
    By WolfBMW in forum Maintenance
    Last Post: 02-12-2014, 03:52 PM
Tags for this Thread
