Results 1 to 10 of 12
    E46 brake warning light
    I always thought this light...
    .... would clear after performing a brake job, to include replacing wear sensors (if necessary), after a certain amount of driven miles.
    Wear sensors are located on front left, and rear right corners (review)
    I performed my brake job about 100 miles ago, and the light hadn't cleared. I dud some research and found the below procedure worked immediately for me, clearing the light.
    1. Place the ignition in position 2, car NOT running.
    2. Press the "I/O" button on cruise control and hold in for 10 seconds.
    3. Release "I/O" button, and press and hold "+" button for 5 seconds, then release.
    4. Press accelerator in and hold, and you should see the light clear. Release accelerator.
    Many may know this already, but I thought I'd post in case some do not.
    Lexington, KY
    Thanks boss, I didn't know that and last time I did my brakes, I had not tripped the sensors so I reused them. I see you pushed your pads to the limit.
    Yep.
    Lexington, KY
    LOL
    Aug 2014
    Leesburg, VA
    I thought you just turned the key to position 2 and waited a ~10 seconds for it to clear. Will try this method on the '00 328i.
    Thanks!
    Charleston SC
    I would of broken out the diagnostic equipment to reset... very good to know, thanks!
    H&R sport springs,
    Jun 2014
    Toronto, ON
    Boss, this light resets itself after a few seconds of leaving the key in position 2.
    Source: I've managed to snag the front sensor wire more than once and have had to replace them.
    anandoc
    Quote Originally Posted by anandoc View Post
    Did not work that way in my case.
    Any E46 I've ever done I just leave the key on acc position 2 for 30 seconds, it's a LOOONG time to sit there and wait.
    Check out my BMW Blog
    Follow me on twitter @smolck
    Yeah... I did not wait 30 seconds. I waited about 10, and when nothing happened, I pressed the buttons as instructed above. They may have done nothing and 30 seconds may have elapsed at that point. Wish there was a TIS for this. Most likely you guys are correct in only needing to leave in position 2, for Saud amount if time (30 seconds possibly or longer)
  1. Blinking Red Oil Warning Light
    By quikryptonite in forum Mechanical | Troubleshooting
    Last Post: 04-13-2017, 01:14 PM
  2. Brake Pad Sensor and Cluster Warning
    By Karl Lazlo in forum Mechanical | Troubleshooting
    Last Post: 05-20-2015, 05:50 PM
  3. Coolant Warning Light when A/C?
    By PirateZHP in forum Mechanical | Troubleshooting
    Last Post: 10-12-2013, 03:11 AM
  4. DSC diagnostic codes with ABS and brake warning lights: what to do next?
    By aurelius in forum Mechanical | Troubleshooting
    Last Post: 07-15-2013, 05:24 PM
  5. Automatic Transmission and Yellow Brake Warning Lights In & Out. Meh.
    By billschusteriv in forum Mechanical | Troubleshooting
    Last Post: 06-28-2011, 11:54 AM
