Results 1 to 5 of 5
    Dec 2017
    Lake Wylie, NC
    Brake Pressure Sensor
    Has anyone had to replace their brake pressure sensor? There are two on the master cylinder. I was hoping the stuck caliper was what was causing the DSC and Brake light to go yellow, but I pulled codes, and it's Pressure Sensor #1. It does not look like a fun job getting to that sensor.
    Salty
    Bone stock at the moment
    I have replaced one of them. See below:
    OE BMW Brake pressure sensor 1 - Mileage 138,990
    Brake Fluid Flush with ATE 200 - Mileage 138,990
    Only reason I did only 1 sensor was (a) they are expensive and (b) only had the code for sensor 1. Car is about to roll over to 170k and no issues.
    Dec 2017
    Lake Wylie, NC
    Thanks, Vas. Do you remember if it was the sensor closer to the front? I keep hearing conflicting info on the position on sensor 1. Did you have to lift up the master cylinder to get to it? Looks like it is going to be a pain to get to.
    Salty
    I've done this. It turned out that the sensor I pulled out just had a bit of dirt stuck in it. That was after a complete fluid flush. If it wasn't such a pain to get to, I probably would have just put the original back in and seen if the problem (trifecta) went away. But I replaced it anyway, and it did fix the problem. There's just very little clearance to disconnect the lines to get at the sensor.
    For mine, it was the #1 sensor, and I could see the actual flaky response on the scan software. (I think it was NCSExpert - you can watch the data come off the sensor live as you press the pedal, which is very handy).
    Dec 2017
    Lake Wylie, NC
    I replaced my sensor, as well. It's such a pain to get to, I didn't want to risk having to do it twice.
    I posted my installation on my restore thread:
    http://www.zhpmafia.com/forums/showt...152#post555152
  1. DSC + Orange Brake lights: Yaw sensor?
    By 2004_blue_zhp in forum Mechanical | Troubleshooting
    Last Post: 08-06-2016, 01:09 PM
  2. faulty brake wear sensor
    By bloodspatteranalyst in forum Maintenance
    Last Post: 07-25-2014, 07:06 AM
  3. Replies: 30
    Last Post: 02-06-2013, 10:11 PM
  4. Those brake pad sensor are not very durable
    By wsmeyer in forum Mechanical | Troubleshooting
    Last Post: 02-04-2013, 08:05 AM
  5. Low Tire Pressure Sensor fail?
    By johnrando in forum Mechanical | Troubleshooting
    Last Post: 07-18-2011, 10:21 AM
