Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Feb 2017
    Sacramento, CA
    FYI I wouldn't buy anything but OEM parts when it comes to the cooling system. Yes the expansion tank is a stress point, but its very safe to assume it will last at least 50k or 5 years.
    Also if you go with FCP good luck getting parts that aren't shipped broken.
    I'm not a purest. Not OEM have always served me well on 95% of the applications. Thank you though. What company would you suggest?
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Jacksonville, Florida
    Quote Originally Posted by phillipjfry View Post
    I understand, and in most cases getting a non oem part will do, but there are certain areas of the car I just don't want to risk it. Cooling system being one of them.
    I would recommend literally any other vendor out there.
    ~Rob~
    Feb 2017
    Sacramento, CA
    Is it the hoses, the expansion tank, wp, thermostat that are all inferior?
    I'm not sure what you mean.
    The OEM parts on our cars are almost always the best thing you can replace the original parts with. The fitment is factory, the quality is high and you know exactly what you're getting. There are a few parts here and there that are arguably (some factually) better than OEM parts. Things like the G.A.S. coolant cap, G.A.S. DISA rebuild kit, Stett boots, viton gaskets etc.
    The expansion tank on the E46 is known to have issues. They fail quicker than they should, because of the high pressure of the cooling system, and the fact that the expansion tank is made of plastic, it tends to crack over time. This is why whenever anyone says "I have a coolant leak and I'm not sure where" everyone suggests the expansion tank first. With that being said, there aren't many other options out there for non OEM expansion tanks, and as long as you replace your expansion tank preventatively, you shouldn't ever get stranded on the side of the road.
    The rest of the OEM cooling system parts are fine and I would highly recommend using OEM parts primarily because if a cooling system part fails, your engine can potentially overheat, and the M54 does not enjoy heat at all. The heads will warp very quickly under high heat without proper coolant.
    Things like washer fluid pumps, tail lights, anything aesthetic or not critical to the motor or trans are usually what people consider to be fine when replacing OEM parts with non OEM parts. If you buy non OEM front control arm bushings and they fail prematurely, your motor won't explode and your trans will be fine. You will just have to enjoy a shitty driving experience until they get replaced. No biggie.
    At the end of the day it's your car and you can do whatever you want to it. Not everyone is made of money and sometimes we have to cut some corners. I'm just giving my two cents about what corners are the least destructive to the well being of the car.
    ~Rob~
    Feb 2017
    Sacramento, CA
    I was talking about which OE supplier parts that are inferior.
    Yeah, OEM parts are the best, some times. But they are also the cheapest possible part manufactured cost to cut costs for the 100's of thousands of vehicals that part is going to go on. It's called value engineering. It's also not the 80's anymore. There are tons of manufacturers that the same parts to OE specs, for a fraction of the cost. Mostly due to labor agreements, and the cost of such a large inferstructor.
    Usually the only parts I do buy 100% of the time, are any electronic widget, sensor, crap like that.
    I do appreciate the input, I'll do a little more reading on the quality of the the parts I buy.
  1. What do you think needs immediate maintenance
    By JPMo in forum Maintenance
    Last Post: 10-30-2016, 07:55 AM
  2. IRZ's Maintenance/Mod Log
    By imola red zhp in forum Maintenance
    Last Post: 09-01-2014, 06:09 PM
  3. First Big Maintenance
    By Indvdl M in forum Maintenance
    Last Post: 04-12-2014, 05:58 PM
  4. So What Other Maintenance?
    By mLuMaN83 in forum Mechanical | Troubleshooting
    Last Post: 10-21-2012, 09:45 PM
  5. Replies: 17
    Last Post: 01-05-2011, 11:34 AM
