Results 1 to 8 of 8
    Loss of power to radio
    So I've spent the day trying to install an Xtrons PB7656BAP head unit. I had it plugged in and functioning. I turned off the ignition and was repositioning and then tried again and now the headunit is not receiving power. Some stray observations:
    • Plugged into the head unit: 1. L-shaped radio input adapter cable attached to the Xtrons-provided radio cable which itself is attached to the factory radio cable, 2. GPS, 3. USB and 4. power adapter cable
    • I have replaced the 15A fuse on the back, no difference
    • When I turn on the ignition, the Xtrons head unit will not power on nor will the buttons light up when I have the headlights on.
    • Swapping back to my factory BMW Business head unit, the radio will light up with the headlights, but it will not turn on. I replaced its 10A fuse as well with no change in result.
    • The HVAC control unit functions normally.
    • All wires to the power cable appear to be intact.
    Thoughts? I am at a bit of a loss because even the factory radio head unit isn't functioning, which suggests its an issue with the car's cabling, but visual inspection doesn't result in any immediate solution.
    There are additional fuses for the radio in the fuse panel, besides the fuse on the unit. Checks those.
    Also, the XTRONS unit does not by default light the buttons on with the headlight. If the unit has power, the buttons will illuminate.
    Have you started the car too? Might have drained the battery.
    I blame the TSE3
    Quote Originally Posted by Karl Lazlo View Post
    I had checked those, but turns out I can't properly count. I checked fuses 7 and 40, but needed to check 41, which was blown. Still not sure why a 30A fuse was blown. Problem solved though!
    Tried that, battery was fine.
    Quote Originally Posted by dkmcclelland View Post
    I blame the TSE3
    Well whaddaya know...
    Lexington, KY
    Good to hear you're rocking again
    Charleston SC
    I hate it when dumb stuff like this happens.... I usually spend at least a half hour remembering all my favorite curse words and how to use them in a sentence
    H&R sport springs,
    A whole 30 minutes? Rookie.
  1. HUGE 3k-5k power loss/dip
    Last Post: 03-19-2018, 04:03 PM
  2. 2003 zhp - power loss
    By shadowpuck in forum Mechanical | Troubleshooting
    Last Post: 11-01-2015, 05:47 AM
  3. Car stalls every now & then with power loss once at quarter tank.
    By Hugh Jass in forum Mechanical | Troubleshooting
    Last Post: 04-03-2015, 05:56 PM
  4. 4k major loss of power
    By Headmaster in forum Mechanical | Troubleshooting
    Last Post: 09-08-2014, 08:17 PM
  5. Check engine light / loss of power
    By Tampa330i in forum Mechanical | Troubleshooting
    Last Post: 02-14-2012, 03:17 AM
