Results 11 to 20 of 21
    Jan 2013
    Florida
    Good point I didn't add which kit i got.
    https://www.theretrofitsource.com/co...kw-repair.html
    PROJECTORS: 2x Morimoto D2S 4.0
    RQ BRACKETS / HARDWARE: 2x G10 Fiberglass / Stainless
    2004 330i ZHP Imola/Alcantara 6MT
    Quote Originally Posted by jonnyd330 View Post
    i just read through the instructions - it's very simple. it looks like the only modification required is trimming the stock headlight bracket to allow the new project to sit flush against the RetroQuik bracket - 5min or less, with a dremel or a utility knife. otherwise it looks pretty darned plug and play... sorry to say, but i don't see how they could've made it any easier!
    Jan 2013
    Florida
    If you are looking at the directions they provide on their page, those are miss leading. I called and they said there were a number of items not included such as the need to dremel out some for the solenoid and then doing the wiring. I found this guide which uses the same Morimoto projectors but not the prefabricated mount included with my kit.
    http://www.zhpmafia.com/forums/showt...o-Mini-D2S-4-0
    His directions are far more complete and make me think this is over my head, worring about the position of everything and if its going to bump when trying to auto level. I'm worried about screwing these things up to where they are completely unusable.
    OK, did they send you updated instructions for the solenoid? the wiring is not a surprise. i guess TRS is assuming that folks buying their RetroQuik kits are aware of what is required before buying the kit.
    that thread you linked is for installation without the TRS RetroQuick bracket, which really takes the guesswork out. most of his trimming is related to that. nothing in the thread was surprising, to me.
    if you've got a dremel - or can borrow one, and know how to use it, you can do this.
    Jan 2013
    Florida
    Thanks for the vote of confidence.
    I guess reading all these treads has scared me from doing it. I found this one that made it look awful and he had the bracket but now after reviewing it I don't think he installed them correctly. It looks like he mounted the projector from the rear and it should be on the front.
    Jan 2013
    Florida
    So after procrastinating for a while I finally decieded to jump in. I got the driver side headlight done today and I am shocked at what a difference the light output is. The kit is no where near plug and play as they elude to in their directions so buyer beware but with that said its a great upgrade.
    Jan 2011
    Martinez, CA
    Thanks for the update! Glad it worked out for you. Did you use JohnD’s DIY posted above?
    Jan 2013
    Florida
    I used a mix of directions and figuring things out on my own since there was not a set of directions specifically that worked for what I was doing.
    Here is a pic of the light output difference between the new drivers side and old passanger side. Its crazy how much more light there is, id say 90% of the light is from the new projector.
    Wow. That’s...impressively bad on the passenger side.
    Jan 2011
    Martinez, CA
    Nice!! Like night and day difference!!!!
  1. ZKW Burnt Bowl OEM Replacements
    By Clemsone46 in forum All Advertisers
    Last Post: 03-03-2024, 07:09 AM
  2. Full ZKW headlight assmeblies with mounting bracket (burnt bowl)
    By [USMC]Skywalker in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 04-02-2018, 07:56 PM
  3. AL Projectors for Burnt ZKW Bowl Fix [found on NAM]
    By GreatFrog in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 09-05-2017, 03:03 PM
  4. Replies: 66
    Last Post: 11-24-2016, 12:00 PM
  5. Burnt fog light bowl
    By Johnmadd in forum Lighting
    Last Post: 08-01-2011, 09:09 AM
