Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 70
    that's the setup i will likely move to - 9's in the rear. i bet you won't rub with those tires, wes - the PSS you ran before are a bit chubbier than the 500s.
    my setup:
    18x8.5 ET38 square, hyper silver
    3mm spacer in the rear
    245/35/18 michelin PSS (tread width is 9.1" - these suckers are wide for a 245)
    stock ride height - ZHP coupe springs, koni yellows up front, bilstein PSS9 dampers in the rear - both set fairly stiff
    camber: -1.0F, -1.6R
    no fender rolling
    no rubbing without 3mm spacer in rear - slight rubbing in the rear under large compressions with passengers in the rear
    Added.
    For those who submit their fitment specs, it would be great if you could add pictures of the setup if you have them available
    Apr 2016
    Katonah, NY
    Here are mine....
    Apex Arc-8 18 x 8.5 et 38 all around (wheels are custom powder coated using prismatic platinum gold)
    Tires are Michelin Pilot Super Sports 235/40/18
    Suspension is Koni FSDs and OEM springs.
    Things to note:
    I also keep a full size spare in the same wheel/tire specs in the trunk wheel well with no modifications.
    I originally wanted 9s with et30 all around for the concavity but I would have had to deal with other issues:
    -I just didn't feel like dealing with having to add in the negative camber (as i was told by APEX)
    -I possibly would have had to roll my fenders.
    -I wanted to use the 235s, rather than using 255s and deal with increased tram lining.
    -I did not want to use 235s on 9s because i was afraid when stretched the ride would not have been as smooth.
    -A 9 inch spare would not fit in the spare wheel well.
    Last edited by joeybananaz18; 04-30-2018 at 05:55 AM. Reason: updated et on 9 inch
    Quote Originally Posted by joeybananaz18 View Post
    Things to note:
    I originally wanted 9s all around for the concavity but I would have had to deal with other issues:
    looking awesome, joey. two OGs in this thread!
    re: your comment about the 9s... i think you're meaning 9.5? the 9" wheel has the same face profile as the 8.5" wheel does, and fits without fender modification or crazy camber settings.
    the 9.5" wheels are a whole other ball o' wax.
    Apr 2016
    Katonah, NY
    Ahhh I forgot to specify, the 9 inchers that I was looking at were the et30s that had the profile 3 face. the et42s have the profile 1 face. I was looking at the 30s specifically because they came in that matte bronze finish. TBH I was hearing mixed things. some were telling me I wouldn't have to do a thing, others were saying I'd need add in the neg camber and modify the fenders. Although I believe that those modifications would be dependent largely on the choice of tires due to shape of the shoulder.
    oh right, the ET30 ones! totally forgot about those.
    yes, tires make a big difference... as well as camber settings, ride height, fender modifications. but 18x9 ET30 is still a very aggressive fitment, i believe more aggressive than 18x9.5 ET35, given the same tire size.
    Charleston SC
    I think you should add whether it's a sedan or coupe since coupes seem to have more room for lower numbered offsets
    H&R sport springs,
    Oh, good point! Will do when I’m home.
    Jacksonville, Florida
    Sedan
    17x8.5 ET 40 Square Setup
    245/40/17 Michelin Pilot Super Sport
    Lowered on H&R Touring Cup Kit - Z4M FCAB's
    Camber front -1.5
    Camber rear -2.0
    No fender rolling
    No rubbing
    ~Rob~
    Sedan
    17x8.5 ET 42 Square Setup
    No rubbing
    Huh, I didn't think APEX made an ARC-8 in 17x8.5" with an ET42 offset. I thought only ET20 and ET40.
    Also, spacers? Fender rolling? Camber?
    Edited first post
    ~Rob~
  1. Apex Arc 8 Decisions and Fitment
    By Newjack in forum Wheels
    Last Post: 10-27-2017, 12:33 PM
  2. Wheel Fitment 101
    By danewilson77 in forum Wheels
    Last Post: 05-02-2017, 11:41 AM
  3. apex 17 x 8.5 versus apex 17 x 9
    By Tucci139 in forum Wheels
    Last Post: 04-28-2015, 07:05 PM
  4. Help with wheel fitment
    By Opish in forum Wheels
    Last Post: 06-12-2012, 06:03 AM
  5. 1 series fitment on E46?
    By Kamal in forum Wheels
    Last Post: 01-20-2012, 02:24 PM
