Results 1 to 10 of 12
    Nov 2017
    Seattle
    Oil pan gasket...anything else while I am there?
    So my oil pan gasket is the next big project on the list, and I just wanted to see what else you guys thought I should do while I am down there, with subframe off and all that wonderful stuff. Here is my list as of now:
    Engine mounts
    Transmission mounts
    flex disk
    steering coupler
    front Sway bar end links
    A/T drain and fill
    just want to knock out as many things as possible all at once. This list is the things that I know are starting to fail, other things are OK right now as far as I know.
    ~ 2005 330ci ZHP Silbergrau | Black cube | Leather ~
    Current Mods: Akebono brake pads, Bilstein B4 Rear Shocks, Beisan Systems VANOS Rebuild, G.A.S. DISA O-ring, Morimoto fog lights, StopTech SS brake lines, Subwoofer tennis ball mod, Switchback Angel Eyes (turn signal), Zimmermann drilled rotors.
    My project thread ---> http://www.zhpmafia.com/forums/showt...into-a-reality
    Charleston SC
    check your sway bar bushings and the condition of your power steering hoses... they tend to start weeping.
    H&R sport springs,
    Nov 2017
    Seattle
    sway bar bushings are OK I think. They aren't cracked or anything, and I don't notice any sounds from them. If they are cheap, I might just replace them while I am there.
    Power steering hoses got a real nice refresh a few months back. No weeping anymore
    On another note, has anyone ever heard of a bad oil pan gasket causing a vacuum leak?
    Charleston SC
    That's definitely possible. Have you refreshed the CCV? Replaced the dipstick tube o-ring
    H&R sport springs,
    Nov 2017
    Seattle
    CCV is new. Dipstick o-rings new.
    Mar 2014
    Denver, CO
    Oddly enough the drain plug. My started leaking after 180k. Also look at your seals (inner/outer/shifter) and see if they need replacing.
    -Jeff | '19 JGC WK2
    Sold: '03 ZHP
    "There is a straight six engine at the front, a manual gear box in the middle, and drive goes to the back. That's page one, chapter one from the petrolsexual handbook." - Jeremy Clarkson
    Nov 2017
    Seattle
    plug is also new dimple magnetic. are you referring to the rear/front main seal? I am unfamiliar with these gaskets but i have heard them mentioned a few times
    Mar 2016
    Madison, Alabama
    Oil pump nut.
    https://m.youtube.com/watch?v=4PHf7U3Tewc
    He talks way too much. Very manly for California
    Family that races together stays together
    2005 330Ci 6MT SGM (x2)
    Nov 2017
    Seattle
    Quote Originally Posted by PetesZ View Post
    Oil pump nut.
    nice one! adding it to the list. I never track my car, and I dont believe it has ever been tracked, but if i have the sump off hey, why not!
    Charleston SC
    I wouldn't mess with the oil pump nut unless it's already loose... I've pretty hard on my car since I bought it at 44k. At 143k I checked the oil pump nut and it was tight as hell...
    H&R sport springs,
  1. Replies: 302
    Last Post: 06-11-2021, 09:20 AM
  2. Oil pan gasket: who has done it and how?
    By Sockethead in forum General -- ZHP Related
    Last Post: 06-20-2019, 11:07 AM
  3. ? about valve cover gasket
    By edlvrt in forum Maintenance
    Last Post: 10-29-2012, 04:23 AM
  4. Is my Valve Cover Gasket going?
    By fryebaby161 in forum Mechanical | Troubleshooting
    Last Post: 05-17-2012, 09:33 AM
  5. Oil Filter Housing Gasket
    By rikdee in forum DIY
    Last Post: 04-04-2012, 10:47 PM
