I'll verify the wire mine are connected to when I get home tonight...
Ok, I'll check and see what plug it's in too...
EDIT: here are the instructions for my latest set. It would appear that you do have the correct wire...
https://cdn.shopify.com/s/files/1/19...04859294682878
Have we completely ruled out a spooky ghost?
Sent from my Nexus 5X using Tapatalk
Um, that would be an angel?
Lol to both!
You are tapped into the correct wire but maybe redo that connection because this is the switch on and off wire, not the main voltage.
To me the "Red" wire at the ECU looks like it should go to the battery terminal, constant 12v.
Wiring AE's you basically have the following.
- 12v constant (Red)
- Ground (Black)
- Trigger wire (Yellow)
- Trigger wire (White)
Depending on the brand of AE's the trigger wires vary. Usually they are "Yellow" and "White".
Sometimes they are "Brown" and "Red". They are typically the small gauge wire.
The relay has constant 12 volts and ground, the trigger wire is basically the switched "ON" power to the relay. So the trigger wire that is tapped to the Red/Yellow wire at the ECU is always "ON" with the ignition. The second trigger wire goes to the footwell lighting to give fade on/off effect.
The diagram with the "SPST Switch" is an option for an On/Off switch inside the cabin. I have one installed so I can shut off my AE's when desired.
It is possible the relay is bad. Good Luck...
This is where mine connects. It's the red wire. Connected to the red with white stripe and yellow bands. The rest is wired a little different than yours because my angel eyes have two colors.
If it seems to be wired correctly and still not turning off you can try this alternate wire below. This my tap for the water pump on my supercharger cooling circuit. It does the same thing: on & off with key.
Im interested in what you find the solution to be. Also thank you for posting a picture of a silbergrau with glossblack grill and angel eyes. Now I know what mine will look like when I complete these mods and I cannot wait
~ 2005 330ci ZHP Silbergrau | Black cube | Leather ~
Current Mods: Akebono brake pads, Bilstein B4 Rear Shocks, Beisan Systems VANOS Rebuild, G.A.S. DISA O-ring, Morimoto fog lights, StopTech SS brake lines, Subwoofer tennis ball mod, Switchback Angel Eyes (turn signal), Zimmermann drilled rotors.
My project thread ---> http://www.zhpmafia.com/forums/showt...into-a-reality
