Results 1 to 8 of 8
    Ocean County, NJ
    Ignition Switch: Symptoms/Replacement
    Greetings from the past, mia familia.
    Quick post to relay my recent issues and fix in the event anyone ends up with the same problems.
    Mileage: 101,800ish
    Symptoms:
    While driving on the highway, I noticed my green cruise control light was illuminated. I never use cruise control and hadn't depressed the button. I pressed the cruise control master on/off, but the green light remained on. A few miles later, the airbag light illuminated.
    Once I exited the highway and had to start shifting, the car would buck during shifting-- like I didn't know how to drive a manual. As soon as I depressed the clutch, I would get a clunk, the RPMs would drop out, and when I completed the shift, I'd get another clunk on reengagement.
    Really weird.
    I got her home and put her in the garage. She had been sitting for about 4 weeks prior to that, and I didn't have her on the battery tender, so I thought maybe I had some low-voltage gremlins going on. Put her on the Battery Tender and came back to her 4 days later. Checked voltage via hidden OBC menu and she looked good. She started right up, and I drove her about 70 miles that day mixed highway/surface streets with no issues.
    A few days later, I went to start her up and noticed there was about a 1 second delay between when I turned the key to the start position and when the starter engaged...
    I backed her out of the garage and started driving and immediately got the green cruise control light, airbag light, and bucking condition again. Pulled off into a Wawa to shut her down and hoped the gremlins would disappear on a restart.
    Rookie error...
    The starter wouldn't engage at all. Good voltage via OBC, but nothing at all when you turned the key.
    I sat and Googled the symptoms on my phone while I waited for someone to come scoop me up. About 10 minutes later, I turned the key for the umpteenth time and she fired.
    Limped her home with the previous symptoms plus random interior lights illuminated.
    Got her in the garage. From there on out, I was not able to get the starter to engage again.
    Troubleshooting:
    Googling yielded several suspects-- corroded engine ground strap, ignition switch, bad battery, clutch switch...
    After running through some differential diagnosis, it seemed that the random lights illuminating in combination with the failure of the starter to engage with good voltage pointed to the ignition switch as the most likely candidate.
    I ordered one up from Tischer and got to work on her this morning.
    The DIY:
    Very easy DIY. Loosen the plastic skirt below the dashboard and remove the bottom clamshell of the steering column. Loosen the two little set screws for the ignition switch and remove. Release the wiring harness.
    Reverse to reinstall.
    Problem solved.
    She fired instantly and I've had no issues after several startups and about 50 miles driven today.
    Hope the family is doing well.
    Back to the grind...
    Jacksonville, Florida
    I've never heard of anyone having this issue before, I'm glad it was an easy fix and didn't leave you stranded anywhere!
    Don't be a stranger Keith, it's good to see you around here!
    ~Rob~
    Good to hear from you. When I had the sporadic no-start issue, I replaced the ignition switch as part of the troubleshooting. At the end, the fix was to replace the EWS unit.
    2005 IR / black / 6MT
    157,000 miles
    Hey Keith! Glad you figured it out. Welcome back and thanks for sharing an interesting one.
    Ocean County, NJ
    Thanks! Always feels like home when I drop in.
    I saw the EWS come up in some threads. THe weird dash/interior lights saved me from chasing this one with lots of parts, thankfully.
    Always great to be back, Rando. Hope you're doing well, my friend. You guys are doing a great job keeping the place going. Cool to see the new faces mixed in with the OGs.
    Charleston SC
    Great to see you here my friend! Some day we'll have to catch up!
    We had that happen in the X5... all kinds of bizarre things started happening...
    H&R sport springs,
    What a bizarre set of symptoms. Great work and thanks for sharing the solution.
    Ocean County, NJ
    Miss you guys!! Love following things on FB seeing the kids and that awesome new ride!!
    It was definitely a curve ball. I rolled the dice on the solve. Better to be lucky than smart!!
  1. FS: Full button switch bar/switch center
    By nextelbuddy in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 04-30-2018, 06:58 AM
  2. Symptoms of bad RTABs?
    By nsk040 in forum Suspension
    Last Post: 09-18-2017, 03:33 PM
  3. Side mirror problem - different symptoms from previous threads
    By Dominic in forum Mechanical | Troubleshooting
    Last Post: 08-10-2016, 09:53 AM
  4. DIY: Window Switch Cap Replacement
    By BMWCurves in forum DIY
    Last Post: 08-01-2015, 05:14 PM
  5. Clutch Safety Switch Replacement / No Start Issue
    By VaTechZHP in forum Mechanical | Troubleshooting
    Last Post: 02-25-2013, 07:08 AM
