Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Lynchburg VA
    Is my Valve Cover Gasket going?
    Here is the situation.....
    My car sat most of last weekend. On Sunday I took it out to drop a movie off at the Redbox and go to the store to pickup a few things. While sitting in the car waiting for my wife to get back from dropping the movie off I started smelling burning oil. After a couple of seconds it passed, so I dismissed it. A few minutes later it came back, and I noticed some smoke coming out of the hood. I cut the car off and popped the hood to get a closer look. When I opened the hood, it looked like the smoke was coming from the passenger side of the engine bay. From what I can tell it looks like oil was dripping on the exhaust (??) and since I had not driven the car in a few days, it pooled up, and burnt off once the exhaust got warm.
    My guess is the Valve Cover Gasket, but I just wanted to see if you guys had any other thoughts. I plan on doing a little closer inspection, and hopefully pin pointing the least this weekend, but I must say that this has me a little worried/concerned?
    Any thoughts of suggestions would be greatly appreciated!
    Thanks!
    Indiana
    From the info you've provided, the first / most obvious culprit would be the VCG, but definitely do as you're planning & get a closer / more thorough look at the VCG area. I imagine it'll be fairly obvious where the oil's coming from if you really get in there with a flashlight & perhaps a mirror. GL!!
    Ocean County, NJ
    Yes, it's most likely your vcg. Most times, if you look at the passenger side rear of the motor, you'll see some burnt oil residue or pooling oil on the heat shield that covers the exhaust like you see in the pic below.
    Lynchburg VA
    That picture is almost dead on.... not quite as much residue, but that is it ...
    Thanks for the info guys!
    EVO 4g Tapatalk
    Vcg.......totally. And do plugs while you're in there. NGK BKR6EQUP.
    Droid + Tapatalk = FTW!
    Yeah, as dw said, do the plugs. I guarantee some if not all are oil fouled.
    Lynchburg VA
    Bah, I just replaced the plugs last spring.... Oh well, guess I might as well replace them while I'm in there....
    Ocean County, NJ
    Definitely worth doing the plugs. My #5 & #6 were seriously oil fouled.
    Droid X. Tapatalk. Use it.
    Apr 2011
    Dallas
    spark plugs: NGK or Bosch?
    My VCG has started leaking too. Right on time -- the M54 in my former E39 did the same at the exact same mileage (~65k).
    Realoem lists a Bosch plug (FGR7DQP) in addition to the NGK quoted above. Pelican Parts sells both but the Bosch is a lot cheaper.
    Anyone have any opinions or knowledge on whether the NGK is worth the extra bucks?
    http://www.pelicanparts.com/BMW/cata..._pg1.htm#item0
    Ocean County, NJ
    I've always read that the NGK was a superior plug.
    Don't recall the exact reasons why, though.
  1. Code P0444 Evap Emissions Control Purge Valve
    Last Post: 03-16-2018, 01:53 PM
  2. Replies: 14
    Last Post: 07-19-2014, 12:25 PM
  3. Carbon-Effects: BMW E46 Carbon Fiber Valve Cover and Fuel Rail Cover
    By kayger12 in forum Product and Storefront Reviews
    Last Post: 10-14-2011, 03:10 PM
  4. For Sale: Pet Cover
    By GMATT in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 06-04-2011, 04:04 PM
  5. P1510: Idle Control Valve, Throttle Body or both?
    By Hornung418 in forum Mechanical | Troubleshooting
    Last Post: 04-30-2011, 05:28 PM
