Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Oil Pan Baffle
    Wow, lot of work. Glad you got it done.
    The big difference is the engine mounts which were totally destroyed. I'm toying with the idea of taking a pressure washer to the underside of the car; There is a line of satanic black diarrhea running from the engine backwards. It's been needing to get done for a while.
    I also did the engine oil pump nut fix, but it was completely superfluous. The nut was on there tight with some loctite. Once it was loosened, I unfortunately didn't have a choice. I think there's a higher chance of it coming undone now that I've "fixed" it.
    Putting in Liqui Moly instead of Mobil 1 made a difference. I can't believe I ever put Mobil 1 in my car.
    The baffle itself I'm still meh on for the one time a year I take it to a track day. Had to buy at torch and suffer through the heat trying to get it on. Not really worth it; Maybe just overfill with oil? I dunno, next track day it'll be good. Next job is going to be all the bushings in the rear end.
    Quote Originally Posted by Fried_Chicken View Post
    That's where I'm at with the oil pan baffle. I'll probably track it 3-4 times a year but afraid that either 1. Some moron on the road totals my car or 2. I don't get to track it as much as I want.
