Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Jan 2016
    Chicago area
    Effing yeti over here gd
    #Yeti4lyfe
    60 is a fairly warm day in the summer. Now seeing that I'm wearing a coat, I see no need to go past 60 and make it a furnace.
    There is no need to set it to 91. Set it to a temperature you would feel comfortable with (ex: 70) and it'll automatically blow whatever temperature air and at whatever fan speed it needs to in order to reach that temperature and keep it there.
    Adjust whether you want it to blow hot or cold air with the slider instead. It's far easier than constantly adjusting the temperature.
    Hahah I typically just like maxxing it at 91 and then cycling back between that having the windows down. I know it's not exactly fuel efficient but I'll do anything to keep myself awake during rush hour traffic.
    1991 E30 Alpinweiß 325iX [SOLD]
    2005 E46 Sparkling Graphite Metallic 330Ci ZHP 6spd
    Aug 2014
    Leesburg, VA
    Owner's manual / BMW suggests setting at 72°.
    Jan 2013
    Central California
    #Yeti4lyfe
    Me too. I only ever use 59 - 63. I don't really care for the digital thermostat. I don't much care for the automatic heater/AC. Don't like the up/down push buttons of the fan speed either. Would rather have manual analog dials. I guess I'm a control freak that way
    Jan 2016
    Chicago area
    Quote Originally Posted by Dave1027 View Post
    I don't care much for the automatic function either. I feel like it doesn't really get rid of the tinkering as much as it should.
    I've been trying to use the central vent adjustment, but that kind of defeats the purpose of an automatic system for me. In the winter before the car heats up enough, I want the vent adjustment at the hottest setting and the fan on low. After the engine heats up, I hit the auto button if I want more heat. Either way at some point I'll have to mess with the vent adjustment.
    For manual controls, my general procedure is to wait for the car to warm up slightly. Put the heat adjustment on the hottest and start with the fan on the lowest. Go up with the fan speed when the engine warms up a bit if needed. When it gets too hot, start reducing the fan speed, and the thermostat after that.
    If anything the manual approach seems simpler to me, and the auto hvac is a bit useless in my case.
    ??? The auto HVAC literally does your entire manual warm up procedure...but... automatically...
    I absolutely love it in the e46. I leave it set on 68 and it'll start blowing warm air once the engine gets warm enough to share. The only time it needs your input is when the defrost is required - then it dumps all available resources to the windshield to get you going. I have zero complaints about this system.
    Jan 2016
    Chicago area
    The problem is the system can't read my mind. I feel the fan speed ramps up too quickly when it's warming up, which leads to tinkering. In the winter, I would say manual/auto is about the same amount of convenience for me.
    The AC control has more of an advantage.
  1. Seat heater on by default
    By anandoc in forum BMW Coding
    Last Post: 01-13-2016, 10:45 AM
  2. Heater going bongos
    By alexandre in forum General -- ZHP Related
    Last Post: 01-21-2013, 09:27 PM
  3. Heater question--always cold air from top vents?
    By tomjonesrocks in forum Mechanical | Troubleshooting
    Last Post: 01-27-2012, 06:26 AM
  4. Block Heater
    By apridge in forum General -- ZHP Related
    Last Post: 11-19-2011, 10:40 AM
  5. Heater is not working properly
    By Linh in forum Mechanical | Troubleshooting
    Last Post: 12-03-2010, 03:30 AM
