Good news!
Good news!
Dropped the car off for a 4 wheel alignment, state inspection and the a/c recharge.
Fantastic! Glad to see it nearing road ready after all the hard work you put into it.
Inspection done, a/c is now blowing crispy cold and the car alignment is great. Spec sheet attached
Put about 100 miles on it and the traction control light/DSC light came on.
Pulled the code and 2 came up for pressure sensor 1 not plausible and faulty.
First step was to bleed the brake system but that did not solve the issue. So I ordered 1 sensor that is throwing the code (second sensor seems fine)
Gauge cluster pic attached. It was 100 degrees today.
Replacing the DSC pressure sensor.
Top is sensor 1
Bottom is sensor 2
Cost currently is $151 before discounts and shipping.
Hope that works.
Replacing the DSC pressure sensor has fixed the issue so I'm happy about that.
Next up on the maintenance list was the maf sensor and I splurged for a 1.2bar gas coolant cap.
How hard was the sensor? I’m getting the same issue with a 5E21 Pressure Sensor 2 code. It seems pretty cramped in there.
