Page 9 of 14 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 135
  1. #81
    Quote Originally Posted by 28firefighter View Post
    How hard was the sensor? I’m getting the same issue with a 5E21 Pressure Sensor 2 code. It seems pretty cramped in there.
    They are cramped in there. Sensor 1 is next to the firewall and that is more difficult to remove then sensor 2. You have to remove the brake hard line out of the way to be able to put a 27mm wrench on the sensor. And remove everything quickly to loose as little brake fluid as possible.
  2. #82
    Oct 2017
    Southington, CT
    i have the occasional ABS error every a month or two, but haven't tackled this yet. 50sKid had a pretty good video on getting it out https://www.youtube.com/watch?v=CvyVCwCAx1Q&t=448s
    Did you find it similar to what he did? That's the way I had planned to do it when I tackle it. I bought then entire master cylinder with the DSC and sensors attached off eBay in 2018. Still on the shelf
    Pete
  3. #83
    Quote Originally Posted by pedro2u View Post
    That is one way to do it but if the DSC unit itself is not bad, then I don't see the need to replace it. Plus you have to code it to the vehicle afterwards.
    I would start off with a full brake fluid bleed and clean the abs sensors on each corner of the vehicle.
  4. #84
    Roughly 75k on these spark plugs. What do you guys think? Ngk states they are roughly a 100k mile replacement.
    I put it a fresh new set since I feel like they were due for replacement
  5. #85
    Good idea to replace the set. Your car will run better.
    2005 IR / black / 6MT
    159,000 miles
  6. #86
    One other issue I was having was not being able to fill up the gas tank fully.
    I installed a new genuine bmw vent valve that sits underneath the intake manifold and that allowed me to fill up the tank without the nozzle clicking off. It looked like it was replaced before with a Vaico brand.
    However the gas gauge was showing the incorrect reading. So a gauge cluster reset did the trick and now the issue is resolved.
    Hopefully these are the last mechanical issues and I can move on to refreshing the cosmetic items.
  7. #87
    Daily driving it now and enjoying it
  8. #88
    She. Looks. Clean.
  9. #89
    I bet Shawn wants to buy this car back.
    159,000 miles
  10. #90
    Nice! That's gotta feel like you just rolled off the dealer's lot in 2004. You want me to burn you a mix CD?
  1. Shawn's 04 IR/Alc/6MT Red Rehab Project
    By ELCID86 in forum Projects
    Last Post: 12-12-2019, 07:43 AM
  2. peter's new ZHP project: Project Estoril
    By slater in forum Projects
  3. 111K Mile Suspension Rehab Now Like a New Car
    By wstr75 in forum Suspension
    Last Post: 10-27-2015, 01:18 PM
  4. Replies: 421
  5. Wanted: DIY suggestions for lower grille rehab
    By aurelius in forum Detailing
    Last Post: 10-05-2011, 08:35 AM
