Results 1 to 7 of 7
Thread: Remove Clutch Delay Valve?
    Palm Beach County, FL
    I'm not the best shifter but I know if I lift the clutch at about 2500 or 4800 my shift is smoother than anywhere else but I feel like that shift point is tiny, so little margin for error... If not perfect, it shudders. In the past when my clutch was blown on my E36 I even was able to shift without the clutch, which was very cool BTW.
    Then
    I read this were I saw a video:
    BMW*have used clutch delay valves on the*E39*and*E46*models, and others, from 1997. These valves have been unpopular with some drivers and they are sometimes removed to leave a conventional clutch action.*The BMW valve is a separate pipe fitting and easily removed.
    So bottom line, will removing this slow down the RPM decrease after letting of the gas and give me more margin or....
    Hankook Ventus V12
    Front: 225/45ZR
    Jul 2011
    Houston, TX
    CDV delete is a very common mod and should only improving your shifting. an alternative is to install a "unlock" valve which keeps the part, but opens up the fluid flow: https://www.ecstuning.com/b-uuc-part...QaAk4TEALw_wcB
    here's a good DIY:
    https://www.e46fanatics.com/threads/...h-pics.763107/
    --Wes--
    Yep and the replacement part that ECS and the like sell is 100% unnecessary
    May 2020
    Toronto, ON
    Lol I find it pretty funny that the bored-out CDV is still being sold. Who would buy them, I guess some schmuck who has not done their research? They were only made so that when the cars were still in the warranty period, it wouldn't be voided
    Jun 2012
    Socal
    To actually answer your question, no it won't affect the rate the RPMs drop at. But it'll let you engage the clutch a bit faster. You just get slightly more control of the clutch.
    +1, when I had my ZHP I had mine removed.
    Quote Originally Posted by sillieidiot View Post
    +1
    Oct 2016
    Vermont
    I removed mine on my ZHP and my 330xi DD, and my clutch action in both cases was significantly better.
    2004 BMW 330i ZHP (52k miles), Jet Black with black leather, MFactory LSD (3.38) with Z4 cover, 18"x8.5" ET38 APEX Arc-8's (Anthracite) with 245/40 Michelin PSS', Koni Sports with factory springs and front and rear reinforcement plates, Shark Injector, Corsa TSE3 cat-back exhaust, TMS under-driven pulleys (water & steering), CDV delete, TMS CF strut brace, K&W CAI, GAS DISA rebuild, TMS pedals, Wheelskins steering wheel cover, roller tray center console, black-out grilles, and WeatherTech mats
  1. Clutch Masters stage 3 330 6spd clutch kit
    By 330i ZHP in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 02-21-2017, 07:28 PM
  2. Clutch Delay Valve Removal doityourself
    By 05ImolaRed in forum DIY
    Last Post: 04-12-2016, 12:37 PM
  3. (Sold) UUC Flywheel, Clutch, Shifter, DSSR, Clutch Line
    By LukeT32 in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 04-16-2015, 08:50 AM
  4. Replies: 40
    Last Post: 11-08-2012, 10:43 AM
  5. Replies: 5
    Last Post: 01-23-2012, 11:13 AM
