Results 1 to 10 of 10
Thread: Chronic Oil Filter Gasket Problem
    Friends - My preventative maintenance has turned to chronic maintenance. Several weeks ago I changed out alternator and the oil filter housing gasket. Later noticed oil on the garage floor. Looked like it was coming from the OFG housing. Took apart, cleaned up and put in new OFG. Took great care to make sure the two faces of the housing were clean and so everything would get seated properly. Now getting more abundant leak. took a good look at the pan gasket and everything seems to be okay there. About to tear down the OFHousing and try again. Must be something I am not considering . . . a special Bavarian chant as I am tightening down the bolts? Any suggestions are appreciated. Best, Dave M.
    2005 Imola Red; Black Leather
    Jul 2016
    Boston, MA
    Quote Originally Posted by DaveInMD View Post
    Unusual. At the risk of stating obvious, donít be tempted to tighten it more...if you strip alum threads itís a problem.
    Are you using a good quality gasket not bought on EBay?
    I have heard of the OFH warping, but itís rare. If I were you I would place it on a piece of glass and check it
    I have also heard replacement OFHís (i.e non original) sometimes have trouble sealing. Is yours original?
    Are all the locating dowels still in place ?
    The gasket does the sealing. I tighten evenly with a quarter-inch ratchet by hand and usually donít have a pblm.
    Clean it all well, and give it another go.
    Quote Originally Posted by Pilot05 View Post
    Just wrapped up but I saw this as I started removing the housing. Good to think of these things and look at some issues with a closer eye. My wife looked at me oddly when I said "Can you go up in the guest room and get that drawing of Paris that used to be in the kids bathroom -- and bring me down the glass -- just the glass."
    we'll see how she runs in the next few days. Thanks again. Be well.
    Interested to hear if it's warped! That may have happened with mine too, but the leak has been small enough that I haven't bothered to do it again.
    Nov 2017
    Irvine, CA
    So.... what's up with this glass? I wanna be in on this joke, too.
    GL and keep us posted
    ZHP Performance Package, Cold Weather Package, Leather, Jet Black/Black/BlackCube, NAV
    ESS Stage 1 Twin Screw Supercharger, Sprint Booster, BMW Perf Intake, Magnaflow Exhaust, Dinan TB & STEP S/W, Ground Control Coilovers, UCC Sway Bars, Apex EC-7 18x8.5 ET38
    Aug 2014
    Leesburg, VA
    Quote Originally Posted by Will View Post
    He's using the piece of flat glass to check that the OFH isn't warped.
    Aug 2011
    Las Vegas, NV
    Are you using the OE Nitrile buna gasket or the Viton Hi-Temp version? I applied a thin coating of Hi Temp sealant and the installed the gasket. Never leaked afterwards. The Viton version is $30 vs the $8 OE one but worth it in my opinion. Take a look at the heat ratings of the material.
    BAVSOUND Stage 1 - UltraGauge - Valentine One - Orion V4's - ARC-8's
    Nov 2017
    Irvine, CA
    Ah! Thanks.
    New Jersey
    I had this problem once, the issue was tightening down the bolts one at a time. If you tighten them all evenly in small increments to the torque spec, it pulls the housing down gradually and evenly ensuring a good seal.
  1. Replaced my Oil filter housing gasket and now,
    By spatchel in forum Maintenance
    Last Post: 02-27-2017, 11:36 AM
  2. Don't fear the oil filter housing gasket
    By Sockethead in forum General -- ZHP Related
    Last Post: 03-25-2014, 04:29 PM
  3. Oil filter housing gasket leak. DIY?
    By 09mageec in forum Mechanical | Troubleshooting
    Last Post: 02-21-2013, 07:45 AM
  4. Oil Filter Housing Gasket
    By rikdee in forum DIY
    Last Post: 04-04-2012, 10:47 PM
  5. Oil Filter Housing gasket.
    By xtremecro in forum General -- ZHP Related
    Last Post: 09-26-2011, 08:50 AM
