Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Inside door side plastic piece clips
    Palm Beach County, FL
    That cool ZHP carbon fiber design plastic panel can still get clipped in, but only the right two clips are still legit. The one on far left is broken, and to make matters worse, maybe from the Florida heat, the plastic panel has bent up and away from the door a bit so even if I fixed this, that pressure would cause problems again.
    So
    1. Do they sell replacement clips just for this part?
    2. Is there a safe way to bend back the plastic piece, maybe with the help of a heat gun?
    Hankook Ventus V12
    Front: 225/45ZR
    Jun 2012
    Socal
    are you talking about the white pieces? yes they have replacements.
    what bending are you talking about? I can't tell from the picture
    FYI those clips can be removed by sticking a large screwdriver into them, turning 90 degrees, and pulling straight out. Easiest to swing by a parts yard and fill your pockets with them.
    P/N is 07-14-9-158-194.
    2005 IR / black / 6MT
    150,000 miles
    Aug 2014
    Leesburg, VA
    It's weird that realoem doesn't show that part used on the coupe.
    Oct 2017
    NH - The Live Free or Die State
    isn't that a sedan? I don't have that trim on my convertible either
    - Pete
    Jan 2014
    OC, CA
    Coupes and verts have cube trim on the armrests, unlike sedans which have individual pieces on the door cards.
    2004 BMW 330CI ZHP, Silver Grey Metallic, Dinan: Stage 2 Software, High Flow Intake,
    Free Flow Exhaust, Front Strut Bar, Stage 2 Suspension System, Staggered Hartge Replica Wheels,
    M3 Mirrors (Side and Interior), M3 Seats
    Aug 2014
    Leesburg, VA
    Quote Originally Posted by pedro2u View Post
    OP has a sedan. I have a coupe & looked up the part for reference/fun = no application.
    Quote Originally Posted by sillieidiot View Post
    You see how it's curling away from the clips?
    Meaning even with new clips, there'll be constant pressure away from the door causing possible detachment again.
    Should I risk using a heat gun or some other temperature related technique to fix this, or will the replacement clip be strong enough to overcome this ....
    Hankook Ventus V12
    Front: 225/45ZR
    You are always DA MAN
    MUCH appreciated
    Hankook Ventus V12
    Front: 225/45ZR
  1. Driver side right side plastic panel loose/curled out
    By Dathaeus in forum Mechanical | Troubleshooting
    Last Post: 04-24-2017, 03:49 AM
  2. Screw Extraction from Intake for Plastic Distribution Piece
    By roadbiker_2 in forum Mechanical | Troubleshooting
    Last Post: 02-15-2017, 03:02 PM
  3. What is the part number of the plastic piece behind the lower grill?
    By wookim.design in forum General -- ZHP Related
    Last Post: 11-11-2015, 11:23 AM
  4. WTB: Headlight Vertical Aim Motor Plastic Connector Piece (White)
    By derbo in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 02-08-2015, 05:42 PM
  5. Side Skirt Clips
    By johnnyrad in forum Mechanical | Troubleshooting
    Last Post: 03-26-2011, 09:13 AM
