Results 11 to 20 of 22
    Aug 2014
    Leesburg, VA
    You might try a small section of Strip-Calk to bridge the gap between the trim & door panel. It will fill any void & stick it in place.
    https://www.3m.com/3M/en_US/company-...3194020&rt=rud
    Jan 2014
    OC, CA
    You see how it's curling away from the clips?
    Meaning even with new clips, there'll be constant pressure away from the door causing possible detachment again.
    Should I risk using a heat gun or some other temperature related technique to fix this, or will the replacement clip be strong enough to overcome this ....
    You can try to slightly bend it back. Sometimes the act of removing the trim will bend it.
    2004 BMW 330CI ZHP, Silver Grey Metallic, Dinan: Stage 2 Software, High Flow Intake,
    Free Flow Exhaust, Front Strut Bar, Stage 2 Suspension System, Staggered Hartge Replica Wheels,
    M3 Mirrors (Side and Interior), M3 Seats
    Palm Beach County, FL
    Quote Originally Posted by PdZHP View Post
    Basically cold turkey, just force it without any heat, etc? I've had bad experiences doing that with plastic... Softer Metals are bit easier.
    Hankook Ventus V12
    Front: 225/45ZR
    Is there actually a reason to use this? Aesthetically won't look horrible because the gap would be basically hidden from passenger view... And it's not like a glue which will help hold the piece closer to the door right?
    Just don't want to deal with extra gunk unless it serves a real purpose that I may be neglecting.
    Hankook Ventus V12
    Front: 225/45ZR
    Aug 2014
    Leesburg, VA
    It's sticky (yet easy to remove) & will fill a gap - only reason I mentioned it. Can't see the issue you're dealing with from here!
    You are always DA MAN
    MUCH appreciated
    You bet. This other part may come handy, it's for the orange clips: 51-45-8-266-814.
    2005 IR / black / 6MT
    157,000 miles
    Thanks for going next level with advice LOL... I'll probably pass on that, I have OCD about sticky and greasy stuff unless absolutely needed, but good to know!
    Hankook Ventus V12
    Front: 225/45ZR
    Awesome, will do!
    Hankook Ventus V12
    Front: 225/45ZR
    Aug 2014
    Leesburg, VA
    Works to hold the rain gutter trim on by the Hofmeister kink, too!
    The one on roof of the car? Ya those go for f$&**$* $500... I just too mine off, never had an issue, forgot about it LOL
    Hankook Ventus V12
    Front: 225/45ZR
  1. Driver side right side plastic panel loose/curled out
    By Dathaeus in forum Mechanical | Troubleshooting
    Last Post: 04-24-2017, 03:49 AM
  2. Screw Extraction from Intake for Plastic Distribution Piece
    By roadbiker_2 in forum Mechanical | Troubleshooting
    Last Post: 02-15-2017, 03:02 PM
  3. What is the part number of the plastic piece behind the lower grill?
    By wookim.design in forum General -- ZHP Related
    Last Post: 11-11-2015, 11:23 AM
  4. WTB: Headlight Vertical Aim Motor Plastic Connector Piece (White)
    By derbo in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 02-08-2015, 05:42 PM
  5. Side Skirt Clips
    By johnnyrad in forum Mechanical | Troubleshooting
    Last Post: 03-26-2011, 09:13 AM
