Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 1st and reverse gear popping out of gear.
    That’s great. Good to hear you are back into business.
    2005 IR / black / 6MT
    152,000 miles
    Quote Originally Posted by FungShui View Post
    Happy to report the car feels great after the transmission swap and new clutch.
    Nice! Sad it was something as big as the transmission, but at least it's now fixed. So what was the actual failure point? And how long had you had the car before this started happening (miles/years)?
    May 2020
    Toronto, ON
    Yeah geez, what a freak issue - sucks that you had to do a full swap but it is what it is. I think I heard Daniel (kakashi169) had this as well when he had his manual swap at first
    Dec 2015
    SF Bay Area
    Thanks!
    I had the car for 11 years from ~86k miles and now with ~133k miles. This was my DD until 2015 and was retired to weekend duty when I purchased my motorcycle. My fleet expanded again and became the extra weekend car. It is adult driven with intention of being a forever car. Most of my shifts are before 3k and I do not track the car. No burn outs or clutch dumps launches. Transmission fluid flushed twice as maintenance before issues arose.
    I'm not sure what exactly went wrong within the original transmission as I did not want to pay for a tear down and failure analysis. The stock shifter engagement was fine and was not sloppy despite the age and miles. I had some extra cash burning in my pocket and decided to upgrade to the Autosolution's SSK. After the SSK was installed, I noticed it was sitting heavily biased towards the right. Shifting into 1st gear was physically positioned as if it was in 3rd gear. The shop told me transmission detents within the shifter are worn and can present itself as such.
    The car drove well and the shift engagement was excellent when I got the car back and following day in the backroads. 1 week later, it gently popped out of the reverse while backing out of the drive way. I did not give it a second thought as I was unable to reproduce the issue again. Later in the day while commuting back home it pop out of 1st gear and again was not able to replicate the issue. I took a mental note of the events and had an uneventful drive home.
    On week two, I shifted into first pulling from a red light and hear pop sound (like the pop sound made with your mouth or finger). By this time it had enough momentum and speed to get into 2nd. The next light I accelerated [~35% throttle input] from 1st. While approaching 2,8XX RPM a startling auditable pop is made [no grinding noise] and found the shifter in neutral. I pull over to take a look at the car and did not observe anything abnormal or out of place. To make a long story short, that day I was able intermittently reproduce this issue only in 1st gear. 1st pop was also random and not a function of throttle input or engine RPM speed. The shop also observed this as well. Oddly enough, 1st gear remained in gear even when they repeatedly bucked the car with a quick clutch release. 2nd to 6th gear did not have any issues.
    Yeah, the shop which specializes in E36 and E46 and transmission supplier never heard or encountered his issue before.
    2007 BMW Z4 M Coupe | Interlagous Blue | Maritime dash and console trim | 6MT
    UUC short shifter, Euro cats, CSL Euro headers, Evolve CSL Intake and tune, TC Klein Smart Design Double Adjustable Coilovers, Dinan strut brace, CDV Delete, ZHP shift knob, Arkym splitter and spoiler, WPC Bearings, ARP rod bolts, Apex Arc-8, VAC Pump Upgrade, Bluebus
    May 2020
    Toronto, ON
    Which shop is this? I try to do all my own work but when something like a rear wheel bearing goes out, that's not something I want to deal with
    Huh...that's very strange for something in the transmission to go out like that at low miles. I wonder if the shifter had anything to do with it? Somehow resting in the gear was not fully seated and wore out the gear...position somehow?
    Do you still have the Autosolutions SSK in there with the new-to-you transmission? If so, is the position the gears still offset from neutral? When I first had my UUC SSK installed, it had some offset issues that turned out to be them sending the shifter assembled backwards.
    Also for some reason I thought you had only had the car for a couple of years, congrats on 10+ years of ownership! Remind me, what else is in the stable currently? I got my motorcycle license over the pandemic and have been lusting for something like a Husqvarna Svartpilen 401
    Dec 2015
    SF Bay Area
    Performance Technic. They work on all generations of BMW but they built a strong reputation supporting the E46 platforms. Seems they also support Porsche and Audis but I rarely see anything besides bimmers. They had a evergreen Z3 M Coupe at the shop last time which looked similar to the one below except some oxidation on the hood.
    The shop thought it was the shifter as well. The issue was still present for the following cases:
    • Reinstalled the shifter
    • Installed a new Autosolutions shifter that was sent to the shop
    • Reinstalled stock shifter
    Huge thanks to Ron @ Autosolutions who participated in a couple debugging video meetings and sent out a replacement shifter to the shop. His customer service is outstanding. In case somebody hasn't read the full thread, the shifter was not the cause of my problem.
    Yes, the Autosolutions short shifter is in the new transmission. The shifter is no longer biased to one side and sits pretty close to stock. The shop also measured the AS SSK throw and found it was 2.5mm longer with the "new used" transmission vs the original.
    I have a 2010 Triumph 675, Z4 M (see signature), Tacoma X-Runner, and MK7 Golf TDI as DD. I'm actually in process of consolidating the fleet to start hopefully start a overland build.
    The Husqvarna looks like a fun bike and the price to entry is pretty good. Triumph Street Triple and Suzuki SV650s are good alternatives if you like naked/streetfighter bikes. My SV650 was the most fun bike by far and equivalent to the Miata of car world.
  1. Car staying in 5th gear.
    By Johnny330zhp in forum General -- ZHP Related
    Last Post: 02-16-2012, 08:44 AM
  2. Gear oil mix?
    By Alphatek45 in forum General -- ZHP Related
    Last Post: 06-05-2011, 01:14 PM
