Results 1 to 2 of 2
Thread: Intermittent lights out
    Just purchased an '03 M-Sport 330i and it displays a different light out often. When I drove it the first time, it said that the right front turn signal was out. That went away and now it says one of the rear lights is out. Is this a common issue with these cars? Any known fixes before digging into the electronics ect?
    Edit: in the prepurchase inspection, it was noted that the front ride height arm was broken. This wouldn't have anything to do with lights going out would it?
    Jun 2012
    Socal
    I would check to see if it's the rear ground issue for the tail lights. Probably have to search for it on e46f. while you're at it, read through the lighting troubleshooting guide to see if you can narrow it down some more.
  1. intermittent rough idle
    By SwiftyM3 in forum Mechanical | Troubleshooting
    Last Post: 11-20-2015, 05:04 PM
  2. Intermittent loss of oomph
    By Asiah119 in forum Mechanical | Troubleshooting
    Last Post: 09-25-2014, 05:08 AM
  3. Temperature gauge shows intermittent behaviour
    By JASMI88 in forum Mechanical | Troubleshooting
    Last Post: 11-08-2011, 10:28 AM
  4. Lights on the left side are intermittent
    Last Post: 10-17-2011, 05:41 PM
  5. Intermittent Electrical Problems...
    By vrcplou in forum Mechanical | Troubleshooting
    Last Post: 09-08-2011, 07:28 AM
