Results 1 to 3 of 3
    Sep 2018
    Austin, Tx
    M3 rear brake retrofit
    Bare with me here, this makes sense in my head. I wasn't sure if this is a suspension or a brake question, but I'm starting here. lol
    On my wagon, Eileen, I still have the 325 trailing arms but have swapped to 330 brakes. The downside to this is I do not have a functional parking brake at the moment. My goal in this project is 2 fold:
    1. I want to have a parking brake.
    2. I want to swap everything to M3 brakes (front and rear, booster, ABS, etc) as well as the complete front suspension.
    The reason for keeping the non-m diff is that I have a 4.44 out of an X3 in the car with a Wavetrac, to get something comparable in the 210 diff would be a $3-4000k minimum adventure. I would rather spend that money on a BBK for the car.
    SO my question is can I put M3 trailing arms on the car and keep the 325 subframe and diff. I would use 330 cv shafts (and obviously flanges on the diff).
    This is why I think it is possible:
    1. The upper and lower control arms are the same for both cars.
    2. The 330 and M3 CV shafts use the same axle nut and it appears the splines are the same od.
    3. The 330 and M3 have the same rear track width.
    You would think I would know the answer to this but I do not and searching is surprisingly difficult consider all the threads about putting M3 brakes on these cars (usually complete subframes). I have all of these parts but they are assembled in various systems and cars and it would require disassembly. Does anyone know?
    Thanks, George
    Current Garage... '00 R11S, '09 HP2S, '12 R12GSA, '00 Black 323iT (wife's), '02 Alpine 325iT (Eileen, Track Wagon), '02 Japan Rot 325iT
    Instagram @ HillPerformanceBimmers
    Email to George@HillPerformance.com
    Oct 2015
    I wish I could help with this, but have zero experience with it George. The only nerds like you will have the answer-))
    Good luck with this project!
    Stow, MA
    Seems like a lot of work for what's still a single piston caliper and only a slightly larger rotor. Why not just swap to 330i trailing arms? Subframes are the same, so you'd only be sourcing axles and trailing arms, and you'd regain Ebrake functionality.
    -Dave
    2004 330i ZHP sedan- 6 speed swapped, Corsa exhaust
    1997 AW 328i- S52 swapped
    2004 IR 330i ZHP 6MT- aFe Stage 1, Shark Injector, RE Underdrives, Dforce LTWs- SOLD
    1997 Technoviolet M3/2/5- LS1/T56 swapped- SOLD
  1. Rear Electric Sun Blind Retrofit
    By cakM3 in forum DIY
    Last Post: 07-13-2023, 03:38 AM
  2. Replies: 19
    Last Post: 06-19-2014, 09:16 PM
  3. Anyone here do rear E brake shoes?
    By Whitexi in forum Maintenance
    Last Post: 09-04-2013, 03:36 PM
  4. Rear Brake question
    By 06ZhP in forum Brakes
    Last Post: 06-01-2013, 07:33 AM
  5. Cleaning out garage sale! Underdrive Pulleys, brake sensor, motor mount, rear o2's, rear pads!
    By vteckiller2000 in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 06-01-2011, 07:27 PM
