Can anyone confirm if a 330CI door is the same as other model doors? Like is a 325ci door the same?
The coupe/convertible doors are all the same, from 316 to M3 CSL:
https://www.realoem.com/bmw/enUS/par...091&series=E46
Doors should all be the same. I replaced my passenger door a few years ago on mine. But I did have to use the harness from my original door since the mirror plugs were different.
'05 330CI ZHP 6MT
'90 325i 5 speed coupe
'02 4Runner 4WD
So I went to the junk yard and happened to find a CI door that fit. Working on getting everything transferred over to the new door. My problem now is the fender I picked up does not match. I guess the headlights are different on the model I ended up taking the door off of. Can anyone confirm if this will fit a 2005 BMW ZHP? https://www.carparts.com/details/BMW...B&gclsrc=aw.ds
The fender you linked looks correct. A good indicator is the side marker location, which is different between early and late models.
'05 330CI ZHP 6MT
'02 4Runner 4WD
