Results 1 to 8 of 8
Thread: m3 brakes
Hybrid View
    Chicago, IL
    m3 brakes
    Can a swap be done? Calipers and rotors?
    6K HID FOGS - 8K DS2 LOW BEAMS - SMOKED LED TAILS - SMOKED CORNERS - V2 AE'S - BREMMER WHEELS -CONTI DWS TIRES - K&N INTAKE - 35% TINT - CF ROUNDELS - CF SPLITTERS - 12" SUB - LED REVERSE AND PLATE BULBS - SUPER CLEAN
    Jan 2011
    Mass
    TRELO, stock 12.8" rotors not working for you?
    2005 BMW 330i ZHP
    2004 BMW 330Ci ZHP A DIY Turbocharger Project!
    My site: www.E46Turbo330Ci.com
    http://www.zhpmafia.com/forums/image.php?type=sigpic&userid=545&dateline=1337626488
    How big are the M3 rotors?
    Chicago, IL
    I have a set of M calipers sitting at the shop. I want my calipers to say M!!!! haha... I love to mod thats all
    Quote Originally Posted by TRELO View Post
    Nothing wrong with that. Believe me, I know what you mean. The ZHP is the only car I've really left alone. All the rest of my cars were modded and then modded some more.
    330i is 325mm x 25mm
    http://www.realoem.com/bmw/showparts...58&hg=34&fg=07
    ///M3 is 325mm x 28mm
    So....diameter is the same....thickness is 3mm thicker on the ///M3 brakes.
    Phoenix, AZ
    So here's the skinny on M3 brakes and non-M3 cars. I did a significant amount of research on this because I really really wanted to run some M3 calipers (all because of that sexy ///M logo on the calipers )
    M3 calipers won't fit the front of non-m3 unless you get new carriers and drill/punch new holes in them. The rears won't fit at all due to the M3's rear end being so different from non-m3's.
    So basically you can run the fronts but your running on modded carriers and really risking it. This right here is why I finally said I won't do it and just went with a set of brake your self rotors on stock caliper/carriers.
    I really have no idea what I am doing
    Western WI
    In order to get the rears to work, you will need a complete rearend from an M3. Since the overall diameter and thickness is so close to ours, you would be better off doing a BBK upgrade.
  1. BMW 330 ZHP Video -- great brakes
    By Marcus-SanDiego in forum ZHP Gallery and Video Section
    Last Post: 11-14-2014, 05:57 PM
  2. What brakes/rotors do you use on your BMW?
    Last Post: 06-27-2011, 02:05 PM
  3. Upgrade to ZHP brakes
    By prowlerflyer in forum Brakes
    Last Post: 06-17-2011, 09:19 AM
  4. Brakes squealing?
    By lilcdkey in forum Mechanical | Troubleshooting
    Last Post: 06-07-2011, 08:37 AM
