Alpha - do you know how to get the grille out of the bumper?
Do you have to take the bumper off, or can it still be attached? Also, does the grille come out through the front or back of the bumper?
Ah. Old thread with a title of front plate delete. Which I have done. I haven't removed my grill but I can tell you that mine was loose. It has several simple "tabs" that I had to snap into place to tighten it up.
Looks like if I were to undo them all, it would have popped right out, from the back, without touching the bumper. May have to weasel it out carefully, but you wont have to pull the bumper.
http://forum.e46fanatics.com/showthread.php?t=750316
One guy pulled his bumper. One didn't. I wouldnt....
i pulled out my mesh grill insert without removing the bumper. I did it to repaint the thing black, cause mine looked grey like my car. It take some force, but it you start at one end, and push firmly, but quickly, it will pop out. Once you pop part of it, you will be more comfortable with it. It is held on by about 8 snaps. Its a pain to get out and in, but much easier than removing the bumper. First time took me about 10 minutes to get it out. Second time, because i knew i wasnt going to break it, it only took about 5 mins. Firm, even force is key, but i would not start lightly and slowly bring up pressure, but rather "pop" it if that makes sense.
David
09 135i Msport 6mt
04 330i ZHP (sold)
David
Like pulling off a bandaid.
Your front bumper is hairy too?
Sounds good, I'll have to try this out soon. Pyre - do you have any more pics of your car? I was thinking of doing the tails and corners clear but wasn't sure how it'd look on black. It looks pretty good to me on yours.
