Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
    Apr 2011
    Dallas
    Don't Let This Happen to You [engine cooling system: upper hose: bleeder screw]
    In the ongoing crusade to save our engines from their known cooling system failure points, I have the following story.
    Driving along recently when I spotted an E46 getting the "helpful shove" of a police cruiser. It was a warm day and I immediately thought "M54 cooling failure." Turned around and found the guy and his dead 325 coupe in a parking lot. Not out of gas, he says. But he did have a leak at the plastic bleeder screw in the upper radiator hose that morning. He zip tied the screw to keep it in place, added some coolant and went to work. Fast forward to that afternoon. Says he drove for about 5 minutes with the temp needle in the danger zone, then the motor just quit. Popped hood, bleeder screw gone, engine devoid of coolant. 120k miles.
    Luckily for him he has an extended warranty, which had already been called upon to clean up the mess of his cracked expansion tank some time ago.
    Anyhow, when you replace your upper radiator hose, go nuts and spring for the $4 brass bleeder screw. [PelicanParts 17-11-1-712-788-M230]
    Ocean County, NJ
    Good info. Thanks!
    Good to know, thank you!
    So......"under warranty", means you can be a complete jackwagon and melt your aluminum block, knowing you have a coolant system issue?
    Apr 2011
    Dallas
    Assuming his warranty is indeed still valid, he'll be getting a new (reman?) motor. All for the grand sum of $50 (deductible per service visit). Pretty sweet deal considering BMW's Certified Pre-Owned wouldn't cover any of the 6 things I brought mine in for just prior to CPO expiration. That was $50 down the toilet.
    Damn....
    Dec 2010
    Hanover, PA
    Good info. I was looking at this a while ago and thought to wait until overhaul.
    Anyone else have experience using the brass bleeder screw on the plastic elbow? It may be common sense, but I've heard caution is necessary to not overtighten the brass bleeder screw?
    I changed to the brass one when i did my cooling system at 130k. I never cared for a plastic bleeder lol.
    "I don't care if the door gaps are straight. When the driver steps on the gas I want him to sheet his pant's." Enzo Ferrari
    I'm a purist. I will have none of this brass business in my engine bay.
    Lol Its like a gold tooth in your cars mouth.
  1. Replies: 23
    Last Post: 10-24-2019, 10:14 AM
  2. Post cooling system overhaul issue
    By SC4ME in forum Mechanical | Troubleshooting
    Last Post: 07-05-2011, 07:28 AM
  3. Don't think this is supposed to happen
    By Muggzie in forum General -- ZHP Related
    Last Post: 04-21-2011, 08:03 PM
  4. Cooling System Overhaul ?'s
    By kpro in forum Maintenance
    Last Post: 04-12-2011, 10:25 AM
  5. Labor Cost: replacing cooling system
    By Linh in forum Maintenance
    Last Post: 11-30-2010, 05:46 PM
