Felt door trim?
I looked into this at realoem and found a piece that was over two hundred dollars so I don't know that I found the correct part.
On my car, on the inside door seal, there is a piece of 3/4" wide felt trim that encircles the door. The majority of this trim appears to have come loose from the seal and removed by the previous owner. It doesn't look very good because you can still see bits of discoloration on the seal from where the felt was glued to it. I would like to replace it.
Has anyone else had this problem? Is there a cheap solution?
I can provide pics if I'm being too vague. I'm not sure how better to describe it.
2004 Alpinweiss 330Ci ZHP 6MT
