What's a DISA valve?
2004 Alpinweiss 330Ci ZHP 6MT
Or you can do it yourself
http://forums.bimmerforums.com/forum....php?t=1628787
What is the function of the DISA valve and what are the sypmtoms of it's failure?
You're talking about the 4k RPM dip that is exclusive to the ZHP. That's the only one that requires the DME to be shipped to NJ.
Since he's talking about the 4k RPM dip, that cannot be fixed by a standard DME flash. So no, he cannot do it himself.
yeah, the 2800-3000rpm dip is cured* by a standard DME update which can be done within an hour at any BMW service department.
* - if it's a software flaw only; if there's a VANOS issue as well, that'll also need to be addressed.
Zebra Horse Power - PSA: The Hypermiling Thread
Kevin Savino-Riker
Cogito Automation, LLC.
I'm new at BMWs.
I am willing to put down $100 dollars down that it can be done by simply updating the DME AND you can do it by yourself! WINKFP and dis is all that is needed. The fact that you have to ship it out to NC must be due to some red tape or just so that the dealership doesn't mess it up since the ms45.1 DME is sensitive. as long as you bypass the DME relay everything will be fine.
Service Measure
Engine Electrical B12 209 05 04/06/2005
Subject
M54B30 MS45.1; Engine Power Drops at 4000 RPM
Vehicle
E46, E60 with M54B30 and manual transmission.
Complaint
Customer may complain of an engine power drop at approximately 4000 rpm during aggressive acceleration.
Cause
Ignition timing retardation due to unfavorable tolerances of DISA valve flap shaft. Vibrations of a DISA valve are interpreted by the knock sensor system as detonation combustion.
Measure
On a customer complaint basis, replace DISA valve with the improved part (PN 11 61 7 544 805).
After DISA replacement, connect vehicle to DIS/GT1 and from DME identification page retrieve the programmed and basic DME part numbers.
Reprogram DME with the latest available DTS CD! SSS CIP software version. DME programming should last for at least 20 minutes and should result in both programmed and basic control unit number changes. Reprogramming of DME clears the long-term knock sensors adaptations. If the knock adaptation values are not cleared, the vehicle will still exhibit the power lack complaint, even with the improved DISA valve installed.
Important:
In the event the DME programming takes only a short period of time (approximately 5 minutes), and the basic control unit part number has not been changed, the adaptation clearing process has not been accomplished.
In such a case, contact Technical Hotline — Drive train via a PuMA case, requesting authorization for DME shipment to Engineering Department for reprogramming. For the PuMA case title use the following: MS45.1 DME KNOCK ADAPTATION RESET”.
^^ thats when the dealership can't figure it out or doesnt want to deal with it. so yes, anyone can do it.
If that was the case (again, only speaking about the 4k RPM dip here), why would BMW NA specifically state that the DME is to be shipped to NJ? Think about it for a moment - they have to remove the DME, package it, ship it overnight, get it returned back to them in a couple days and go through a re-installation process of the DME (total PITA if you've ever seen it done). Not to mention, they give the owner a loaner car during this period (at least they did when the car was under warranty).
If it was as easy as a DME flash at the dealership, why wouldn't they do it that way instead of all the hassle I described above? The answer is that the knock adaptation fix for the 4k RPM dip is not something that can be flashed by the GT1 at your local dealer or by someone with a laptop running some diagnostic software.
I'm sorry but, You're incorrect my friend.
You use WINKFP to update the DME. Then use DIS to clear ALL of the adaptations. done.
The DME is actually very easy to remove. 4 allen bolts, a plastic cover. 5 ecu connectors and unclipping the DME from it's plastic shroud iirc.
redtape and the dealership not wanting to deal with is likely the answer. dealerships do not know how to use WINKFP. Since it is BMW factory software.
But I can provide closure.
I'll pull up DW77's software version on his sharkinjector thread. and show a screen cap of WINKFP with the EXACT same version number. If needed.
