Results 1 to 10 of 11
Thread: Gear oil mix?
    Duluth, GA
    Gear oil mix?
    So the ecs differential kit came w/ 1 quart of redline. That not enough. Can't get redline locally.
    Any compelling reason why I can't top it off w/ valvoline synthetic w/ same specs. I'd like to wrap it up today.
    Thanks
    -ADAM
    Jan 2011
    PNW
    None that I can think of. As long as both oils are the same weight, full synthetic, and have the same ratings, you should be fine. I actually just resealed my diff cover this last week and I only used 1 quart of oil. it says to use 1 liter (quart) and the bottle is .964 liters, so for me that was close enough. I don't think .36 of a liter will hurt the diff. But some people are really anal about measurements, so just my 2 cents. GL
    Ebay headers | 3.38 diff | 2.5" cat-less exhaust | K&N intake | AA stage 1 software | UUC stage 1 light flywheel and clutch | UUC Evo 3 ssk | Driver Mod |
    Quote Originally Posted by ZHP-FTW View Post
    .036 of a liter.
    I qt is enough bro. The kit came with what you need.
    Duluth, GA
    Car was level. Oil wasn't quite where the bentley said it should be. Went ahead and topped it off. Didn't take much at all though.
    -ADAM
    Ocean County, NJ
    Yep-- mine took more than a quart as well.
    No worries on the mix, Adam.
    I'm not sure if I would mix different brands. Mixing the same brand is fine, but the different additives between brands could result in negative effects. Redline is Ester based and can be quirky when mixed with other conventional Group III/IV oils. Regardless, I doubt you will have any issues.
    My Project Thread
    Register Your ZHP | CoolantSnitch
    2005 ZHP 6MT Mods: AFE Intake, Carbon Fiber Hood w/ M3 Bulge, Meyle HD FCAB's, Zionsville T-Stat @ 88°C, Stewart WP, BMW Perf. Rotors F+R, Oil Temp & Press. Gauges, Alcantara Wheel w/ CF Trim, Alum. Pedals + E-Brake, Black Kidney's, Aux Input, Beltronics RX-75 Pro Radar Detector, Beisan Seals + Rattle Kit, Armrest Delete, Schroth Harness, StopTech Pads, SSR Comp-H's
    Ocean County, NJ
    Good info, Master.
    Droid X. Tapatalk. Use it.
    Duluth, GA
    Quote Originally Posted by MasterC17 View Post
    Agreed. I think I'll consider today's work a "flush" and do it again with my next oil change. Its easy enough.
    Probably not a good idea to mix a polyol ester oil with mineral... Or anything else really. I had a full day and wanted it done lol.
    -ADAM
    Dec 2010
    Hanover, PA
    Sounds good. Good info.
    Jan 2011
    PNW
    Haha, oops, missed by a decimal point. Thanks Dane. I meant .036 isn't anything to worry about.
  1. EXTREME rough idle at R and D gear, but ok in P & N.
    By mikeyb74 in forum Mechanical | Troubleshooting
    Last Post: 10-19-2011, 06:53 AM
  2. 3rd gear hesitation or something...
    By kpro in forum Mechanical | Troubleshooting
    Last Post: 04-22-2011, 09:50 AM
  3. ZHP Mafia Gear?
    By HaloArchive in forum General -- ZHP Related
    Last Post: 04-11-2011, 07:00 AM
  4. Trouble moving stick shift into gear
    By Go Horns! in forum Mechanical | Troubleshooting
    Last Post: 03-11-2011, 11:07 AM
