Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Need some input on suspension replacement
    Wa
    My tires are bottoming out in the front wheel wells when I hit bumps at speed and I think it's because my suspension is shot. I'm running 225/35r20 on 20x8.5 wheels with 35mm offset. From what I have read, I should not be bottoming out with these so I assume it's because by struts are worn.
    So from what I have read, I'll want to not only replace the shocks and struts but also want to replace some bushings. What bushings do I need?
    Which brand/type of shocks and struts do you recommend? I don't see myself lowering any time soon since my wheels barely fit as it is (although I may downsize someday?). I'll probably want a heavy duty shock since my wheels are fairly heavy.
    2004 Alpinweiss 330Ci ZHP 6MT
    Phoenix, AZ
    How many miles do you have on your car? Honestly if it is over 50-60K then I would replace a good number of "stock" components
    http://www.realoem.com/bmw/showparts...08&hg=31&fg=10
    Definitely replace item 1 below if you get new struts.
    On the rears, I would get Rogue Rear Strut Mounts (RSM). These are by far the strongest and best RSM's on the market. PERIOD.
    http://www.rogueengineering.com/rogue/RSM.html
    If you haven't done so yet, i would recommend you replace your Front Control Arm Bushings (FCAB) as well. Treehouse racing, Powerflex, UUC or even OEM are all good choices. This will fix your fronts from moving "front to back" in the wheel well, when braking and accelerating.
    Feel free to post up any other questions. I have done more suspension stuff than I care to admit
    I really have no idea what I am doing
    Dec 2010
    Hanover, PA
    I was bottoming out the rear on my e30 - it ended up being the rear shock mounts.
    Those were/are a wear point that is always good to check.
    And +1 on how many miles do you have on the car?
    Wa
    90k
    Ok, so I need those guides for the front, front control arms bushings (how many total for both sides? are they all the same p/n?), and then of course shocks/struts.
    What is the advantage of the Rogue unit over OEM?
    Phoenix, AZ
    FCAB's are sold in a pair. Go for treehouse racing if you can/are available. And use White Lithium Grease on any and all poly bushings. The FCAB's should come with the lollipops, if not you will need to get them pressed in at a shop. The lollipops are the metal bracket that the bushings go into (number 6 below)
    RTAB's are sold in a pair. Rogue RTAB's are poly vs the OEM which are rubber. That and there is no way that you will donut your Rogue's where it's definitely possible to do that to the OEM. I can speak from experience on that one.
    Wa
    Ok, one pair of FCAB's, two guide supports, one set of Rogue rear strut mounts, and four shocks/struts. Right?
    Does Bilstein HD sound good for shocks/struts? Or should I go with sport? Do the sport struts work with stock and lowering springs?
    Lebanon, OH
    Just get meyle hd cabs, new fsm's, new rsm's, and new suspension setup.
    You may even need control arms...if your suspension is that worn out.
    I would look into the zhp suspension kit.
    Done.
    Droid + Tapatalk = FTW!
    "Flame suit NOT REQUIRED!!!"
    Wa
    You can't replace the ball joints in the control arms? I haven't checked the two ball joints for wear yet.
    Ocean County, NJ
    Quote Originally Posted by cparker View Post
    Not with the stock control arms. Some aftermarket arms such as the Meyles have removable ball joints.
    Droid X. Tapatalk. Use it.
    2005 ZHP, Alcantara, Silver Cube, Nav, Sharked, BMW Perf Intake, BMW Perf CF Strut Brace, CF Valve/Fuel Rail Covers, Shadowline Grills, CF Splitters, Fog Light Inserts, LED Interiors/Plate Lights, Euro-mirrors, CDV Delete, Beisan vanos, GAS DISA, BP Coded
    2017 Alfa Romeo Giulia Q4; Sport Package, CW Package, Nav, Sunroof
    Lebanon, OH
    The kit is $499.00 and. Has the shocks/springs/control arms/front sway bar and bushings. Then all you need to pick up are cabs, fsm, rsm.
    Done.
  1. OEM BMW Auxiliary Input
    By Tampa330i in forum DIY
    Last Post: 12-23-2018, 04:29 AM
  2. BMW OEM Auxiliary Input DIY doityourself
    By kayger12 in forum DIY
    Last Post: 03-25-2012, 09:13 PM
  3. Suspension replacement cost?
    By HokieZHP in forum Suspension
    Last Post: 06-15-2011, 05:45 PM
  4. Factory Auxiliary Input Kit
    By pleasecorrupt in forum Audio | In Car Entertainment (ICE)
    Last Post: 03-29-2011, 10:48 AM
  5. Need some input
    By VA//M3 in forum Mechanical | Troubleshooting
    Last Post: 02-28-2011, 11:05 PM
