Results 1 to 10 of 12
    Chapel Hill, NC
    Lights on the left side are intermittent
    So I posted a few days ago about my left Xenon going out. But then it came back on...then off again then back on. Now it works but then other times doesn't come on. I'll restart my car and then it will work again. I thought my bulb was dying but now the little car indicator on the dash says my left rear ligh is out. However, it doesn't seem to be. I was wondering if this was a fuse problem and not a bad headlight/tailight?
    What do you guys think?
    Quote Originally Posted by HokieZHP View Post
    Try to switch the HID bulb first to see if that is the bulb problem. If not the bulb problem, that should be you xenon ignitor is gone. Get one from ebay for about 50 bucks. It will solve your intemittent Xenon light problem. Regarding the faulty tail light, you need to reinforce the ground wire in the tail light panel. That wire is too thin and it will burn out easy. So go to buy a wire and re-wire the ground to the light panel with a wire clip.
    Good lookin out Doctor.
    HTC Thunderbolt+TT
    Chapel Hill, NC
    Quote Originally Posted by drfreeman View Post
    Spot on! This is exactly what I was told yesterday by my mechanic as well. I've already fixed the taillight. Now just need to fix the igniter.
    Thanks
    -Chris-
    spencers Guest
    So, the ground issue was fixed, yet the xenon lamp is still acting up??
    Chapel Hill, NC
    Quote Originally Posted by spencers View Post
    Well so far it hasn't but I didn't assume that fixing the ground wire to the taillight would fix the xenon as well. I thought it was a bad igniter. I'll look into it though. Would anything else cause the xenon to not always turn on?
    -Chris-
    spencers Guest
    The ballast could be culprit as well.
    The tail lamp grounding fix should solve the xenon issue, at least from what I've read in the past. Odd, huh?
    Chapel Hill, NC
    Little update. The left side xenon still only turns on sometimes. It takes me 2-4 times of turning the lights on and off to get it to turn on. I think it might be the igniter. Any other thoughts?
    -Chris-
    spencers Guest
    Did you swap the ballasts to see if it follows? You could even swap the igniters to see if the problem follows.
    Chapel Hill, NC
    Haven't done the ballast yet. I'm guessing the igniters are cheaper so I might go ahead and replace that and see if it fixes the issue. Is it easiest to get one at the dealer or is there a cheap oem one online besides eBay? I looked around a little but had no luck.
    -Chris-
  1. trunk interior: left-side tray removal?
    By aurelius in forum Maintenance
    Last Post: 06-03-2011, 04:41 PM
  2. For Sale - Tail lights and corner lights -- spray tinted
    By TRELO in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 05-13-2011, 07:07 AM
  3. For Sale: E46 BMW Sedan Side Markers, Coupe Side Marker, Hood Shock
    By MasterC17 in forum BMW 330 ZHPs For Sale (vehicles only)
    Last Post: 03-18-2011, 06:35 PM
  4. Water spots left behind
    By jjcools in forum Detailing
    Last Post: 12-30-2010, 07:27 PM
  5. WTB: Imola Red BMW E46 330 driver (left) side mirror, whole or cover only.
    By nk_zhp in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 12-20-2010, 08:26 PM
