Wonder if I can buy just the bolt somewhere.
I have had no luck finding that bolt at ECStuning (discontinued).
Searched high and lo. It's called a fillister-head screw according to relaoem:
07 Fillister-head screw M10X25 1 07/2007 07119920150 ENDED
This the one I got for my car. P/N from realoem, using my VIN.
I dunno why yours would be any different?
http://www.ecstuning.com/Search/07129905534/ES16139/
Sent from SIGFest 2012
Thanks Dane, you posted the answer 1 minute before I found it.
Sorry, another dumb question.
I got my pulleys & belts back on last night and the car put back together, but it seemed that the A/C pulley wasn't quite sitting flush. I had it tightened as far as it would go and the belt was hanging off the back of the pulley a little bit. I couldn't get a picture because it was too dark. The old A/C pulley had belt marks in the middle with room to spare on either side.
Looks like I installed a wrong part. Can you confirm? This is the one I ordered:
ECS Pulley
The old A/C pulley I took off looked exactly like it but it wasn't an BMW OEM part so I couldn't get the proper part number. Do I need to order this instead:
ECS A/C Tensioner
Yes, the second link is the AC belt tensioner.
Your first link is for the idler puller (the one that attaches to the alternator top bolt).
