OK, I did the VCG back in december once i noticed it was leaking out of the back left corner and into the 1st cylinder spark plug tube.
not too out of the ordinary. replace VCG and spark plugs. Upon start-up post replacement, i start throwing SES light. no big deal it's a secondary airflow light, once car reaches idle, it's running fine.
June comes around and i notice some oil in the first cylinder spark plug tube again, not nearly as much. just a bit. car runs fine. still have SES, but it really doesn't bother me and spending money on this part just doesn't seem worth. take it into a shop (RaceWerks in Virginia Beach, VA) and he checks out the secondary intake confirms that it's no big deal, replaces VCG because, he says they fail every now and again. car still runs fine.
well now this is August and i randomly check the spark plug too and there's a little oil in that bitch again. Any thoughts on the issue would be greatly appreciated! Again car runs fine, and checked out well after Racewerks did the once over on it. idle seems good. occasional (once every few months) throwout bearing chatter, but clutch is Fine and i'm not replacing the T/O bearing until i do the clutch in the next 10-15k.
car has 122k on the ODO.
