Results 1 to 7 of 7
    Bay Area, CA
    serpentine belt replacement with what else?
    Planning on installing a new serpentine belt. Are there any other items I should replace as preventative maintenance while I am there? I was reading that some replace both the idler and tension pulley. Also, how do i remove the automatic transmission fan? Thanks.
    diy for serpentine belt: http://www.zhpmafia.com/forums/showt...ntine-Belt-Diy
    trancenation's Alpine Weiss ZHP
    The DIY shows the tools for the fan, just doesn't mention how to do it. The 32mm wrench and the hammer. It is reverse threaded. Put the wrench on the fan nut, and use the mallet to give it a good couple of whacks to loosen it (hit it clockwise if facing the fan from the front of the car).
    Best DIY for removing fan is at WWW.beisansystems.com. under procedures, double vanos, fan removal. You should replace AC belt and all 3 tensioners as well.
    HTC Thunderbolt+TT
    Seacoast, NH
    And replace the plastic water pump pulley with a metal one.
    "The server is too busy at the moment. Please try again later."
    2009 Horizon Blue Mini R56 Cooper S 6spd
    2012 Pepper White Mini R56 "Justa" Cooper 6spd
    On the hunt for an e30, z3, or 318ti...
    Baltimore, MD
    Quote Originally Posted by mikeyb74 View Post
    Metal Impeller Fans have bearing issues. BMW cleared that up with the Composite Impeller Fan.
    Porsche 944 Turbo Build
    My ZHP Build 2004-2014 RIP
    Seacoast, NH
    That's on the water pump but I'm talking about the pulley.
    Baltimore, MD
    I am mistaken. Yes, OP, Get a Metal pulley. Hell...Underdrive em Rogue Engineering Pulleys FTW!
  1. BMW Windshield replacement
    By Jorge86 in forum Maintenance
    Last Post: 05-24-2015, 09:16 AM
  2. AC and Serpentine Belt Diy doityourself
    By danewilson77 in forum DIY
    Last Post: 07-13-2013, 02:51 PM
  3. Drive Belt Snapped -- Cause?
    By Luigi in forum Mechanical | Troubleshooting
    Last Post: 06-27-2011, 09:07 PM
  4. CAB replacement
    By Speedracer in forum Suspension
    Last Post: 05-24-2011, 02:26 PM
  5. OE BMW Seat Belt Holder
    By mikeyb74 in forum Product and Storefront Reviews
    Last Post: 03-20-2011, 05:16 AM
