Results 1 to 7 of 7
    Central NJ
    Fuel system issue
    When I try to start my car on a cold start, it has a little trouble. I need to press the gas pedal to have it fire up, but after it has been running it will start up no problem. I think there might be restriction in the fuel system which is causing this, but I haven't run a fuel pressure check yet. I did replace the fuel filter, same problem. I was wondering if it might be the fuel pump? Any suggestions? Its an 04 330ci zhp in case anyone wants to know.
    Could it be bad spark? May try to swap plugs if you haven't done in a while. NGK BKR6EQUP.
    Central NJ
    replaced the spark plugs, replaced the battery, checked the coils. I don't think it is anything electrical
    The worst part is my OBDII reader can't detect anything in the fuel system, or at least I can't figure out how to diagnose it
    I guess it could be fuel pump.....injectors.....?
    Are you throwing any codes? Without codes, you'll really need to check fuel pressure. Here are some numbers from AllData Pro
    Did this selecting a 2003 since I can't read your mind, but should be the same all around for the M54.
    Fuel Pressure M54 Engine
    Fuel Delivery Pump
    Operating Pressure
    bar 3.5
    Delivery rate >/= 2.25 L / min.
    X5 SAV
    Typical current consumption
    A >7
    Passenger Car
    A <9
    NOTES:
    RPM Range 620 - 800
    Engine at operating temperature.
    See: Idle Speed
    Injectors and Lines, Fuel Pressure Regulator
    Test pressure / nominal value.
    bar [ ±0.02 ] = 3.5
    Injector Valves, Start Valves
    Testing pressure.
    bar [ ±0.06 ] = 3.5
    Nice post ^^
    Central NJ
    After almost 1 long year of the car taking a few cranks to start... I FINALLY FOUND THE PROBLEM. It was the darn fuel injectors!!! > 2 out of the 6 were leaking. No fuel pressure, so the engine became flooded every time I tried to start it. Finally replaced the leaking injectors and, as they say, the rest is history! I should have taken your advice and checked the injectors a LONG time ago, hah sorry! You guys def. know what you are talking about.
  1. BMW E46 330 ZHP SRS Airbag Issue
    By danewilson77 in forum Mechanical | Troubleshooting
    Last Post: 07-15-2013, 09:28 AM
  2. Brake issue?
    By DirtyPillows in forum Mechanical | Troubleshooting
    Last Post: 08-09-2011, 02:41 AM
  3. Cooling System, Fuel Pump, CABs Done
    By echo46 in forum Maintenance
    Last Post: 08-08-2011, 11:18 AM
  4. Post cooling system overhaul issue
    By SC4ME in forum Mechanical | Troubleshooting
    Last Post: 07-05-2011, 07:28 AM
  5. Fuel
    By Sideshow in forum Performance
    Last Post: 03-15-2011, 08:41 AM
