Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
    Fayetteville, NC
    Exclamation Alignment specs for ZHP unique or not?
    This was discussed somewhere else and now I can't find it - I will be getting new tires (Conti DWS - staggered OEM sizes) soon, and an alignment - hopefully it will cure the steering wheel vibration that occurs at around 80 mph - probably a mixture of out of balance and worn out OEM tires and out of alignment (25k miles on the car right now). i am gonna have the shop check the CABs at the same time, too.
    However I need to make sure that I get the correct alignment - are the ZHP alignment specs different than sport pkg or regular 330Ci? I need to make sure the shop is aware of this, and also possibly need to find a source to get the spces IF they're indeed unique to the ZHP.
    Thanks in advance for any feedback/info on this matter
    Western WI
    Not special. Use the Sport Package settings.
    Fayetteville, NC
    Ah, Thanks! - glad to be 'not special' in this case, as it simplifies things...
    ...so i guess the 'more negative camber' thing with ZHPs is a myth, huh?
    All ZHP owners should strive to have this much negative camber.
    Dec 2010
    Hanover, PA
    ^ Wow.
    BlackBerry. Tapatalk.
    Baltimore, MD
    Good for your tires...
    Porsche 944 Turbo Build
    My ZHP Build 2004-2014 RIP
    Quote Originally Posted by mimalmo View Post
    +1
    HTC Thunderbolt+TT
    For those of you with lowered cars, the stock alignment may need to be tweaked. Lowering changes suspension geometry.
    Sent from my DROIDX using Tapatalk
    Western WI
    That's why you should get an alignment after a drop.
    Fayetteville, NC
    Thanks for all the clarifications - my car is all stock so now I know which specs to use, which i am pretty confident the shop also does - just wanted to be sure that they didn't have to do anything, um, special with the ZHP when they do the alignment.
  1. BMW 330 ZHP alignment and data + Pics
    By danewilson77 in forum Suspension
    Last Post: Yesterday, 07:30 PM
  2. Alignment suggestions
    By rickflairne in forum Maintenance
    Last Post: 05-10-2017, 01:01 PM
  3. E46 Alignment Specifications
    By VA//M3 in forum Suspension
    Last Post: 05-23-2011, 03:28 PM
  4. Powerflex FCAB's Installed and Alignment Done Today
    By mimalmo in forum Maintenance
    Last Post: 02-04-2011, 02:54 PM
