AllData confirms. There are 3 alignment specs for the E46:
Stock
Sports Package
"Rough Road Package" <-- ??? xI models I suppose...
Here are the specs for the Sports Pakage
Front axle:
Total toe - 0°14' ±8'
Camber (Difference between left/right max. 30) - -43' ±20'
Track differential angle with 20°lock on inside wheel - -1°34' ±30'
Caster (Difference between left/right max. 30')
With +/- 10 degrees wheel lock - 5°36' ±30'
With +/- 20 degrees wheel lock - 5°47' ±30'
Front wheel displacement - 0°±15'
Maximum wheel lock
Inside wheel (approx.°) - 43.6
Outside wheel (approx.°) - 35.6
Rear axle:
Total toe - 0°16' ±6'
Camber (Difference between left/right max. 15') - -2°04' ±15'
Geometrical axis deviation - 0°±6'
To be clear, these are not the specs for "sport", which is the ZHP equivalent for alignment specs, right?
That is correct sport specs applies to the ZHP.
