Results 11 to 20 of 28
    Quote Originally Posted by llll1l1ll View Post
    Unfortunate, since now would be an opportune time to replace everything there.
    Agree.
    HTC Thunderbolt+TT
    Jan 2011
    SoCal
    i would love to do all that but yeah, the times are tough right now, just being honest. not proud of it though
    2004 ZHP Saloon
    Location - CA
    Very Proud Owner
    Apr 2011
    Middle River, MD
    Hey man, sometimes you can only do what you can afford. It happens to the best of us. Don't be ashamed. You'll fix the rest at the right time.
    Apr 2011
    Dallas
    Let us know if your idler & tensioner pulleys are still there. The root cause of these symptoms is often the idler pulley, tho the serpentine belt can certainly shred all by itself.
    What's your current mileage?
    Fix'd and +1. No shame in doing what you can to keep your wheels rollin. Hell....I cheaped out on tires, and put them on BBS rims. Didn't really want to, but the Khumo's fit my budget better.
    Albert, do your best.
    Dec 2010
    Hanover, PA
    Albert - Hope you were able to bring the car to a stop safely and quickly.
    You mentioned leaking coolant? Did you notice an overheat? Keep an eye out for continued coolant loss. That symptom could be indicative of moar problems - I had this happen to me. Be sure to keep the coolant level in the right zone (use the float). You can drive like this for a while.
    FWIW, while we all like to talk about what fluids and parts we should be putting in our cars - just know that you can limp along with universal coolant and aftermarket parts. My indy mechanic does it on his own cars - but that's based on his resources and skills.
    The conti belts aren't too bad - price-wise - depending on where you can find them. AutohausAZ has them for 9.77 (AC Belt) and 18.15 (Drive Belt). Idler pulley is 24.68 (OEM), Accessory pulley is 17.20 - for hydraulic tensioners.
    Redondo Beach, CA
    ^^ Yeah, what happened with the leaking fluid?
    The most likely scenario is that the water pump failed and froze, leaking coolant and shredding the belt.
    William.
    2006 CiC 6MT
    ZHP, Cold Weather, Xenon
    Quote Originally Posted by billschusteriv View Post
    Yes....his car went into the red. He lost coolant...but upon re-fill, system appeared tight?
    Dec 2010
    Hanover, PA
    Thanks DW. I missed that.
    Quote Originally Posted by wsmeyer View Post
    William.
    Good call. You could fill the system and check for leakage around the water pump shaft or from weephole on the underside of the pump.
    Another possibility - if the water pump was fine and the belt shredded, the coolant temperature could've risen high enough to pressurize the system and lift the relief in the coolant cap. You would see some coolant spots around/under the cap area.
    Hopefully the rest of the system is intact and you don't have any small leaks around the radiator, expansion tank, upper thermostat (or lower if you have an automatic), or other plastics.
    Keep us posted!
  1. Battery for BMW E46
    Last Post: 07-30-2018, 11:36 AM
  2. Replies: 27
    Last Post: 06-20-2013, 06:38 PM
  3. Need some Battery Replacement pointers
    By kpro in forum Maintenance
    Last Post: 05-16-2011, 09:26 PM
  4. Anyone have a good power steering fluid flush DIY?
    By johnnyrad in forum Maintenance
    Last Post: 03-28-2011, 04:57 AM
  5. My low coolant light came on today
    By 3ZHPGUY in forum General -- ZHP Related
    Last Post: 12-20-2010, 06:49 PM
