Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 120
  1. #21
    Plugs were replaced but how about vcg?
  2. #22
    Never.
    HTC Thunderbolt+TT
  3. #23
    If the vcg let's go it will put oil on the plugs and will definitely stutter a car to putters.
  4. #24
    No oil on plugs. All replaced. Nothing in the wells?
    HTC Thunderbolt+TT
  5. #25
    Sorry I couldn't help.
  6. #26
    Too lean?
  7. #27
    Too lean?
    No codes now...just running really bad.
    HTC Thunderbolt+TT
  8. #28
    ND
    QUESTION: The lil vent hose that come off of the fuel filter does what exactly?
    Sorry to hear you're still having problems Dane.
    I don't know a whole lot about that vacuum hose but the way I understand it is it operates the fuel pressure regulator which is part of the fuel filter. It goes from the filter up to that F shaped fitting on the intake hose. Maybe the hose is cracked or torn somewhere along the line?
    Or possibly fuel pump problems?
    Good luck.....Barry
  9. #29
    Thanks Barry.
  10. #30
    Lexington, KY
    Dane, that is not fun to read.
    You mention in your first post the faulty camshaft position sensor.
    P0301 reads also this: Crankshaft speed/acceleration is monitored by crank sensor. Time for each cylinder combustion is compared against avg. of others. If time for cylinder 1 is longer, fault will set.
    Is the crank sensor the same as the camshaft position sensor?
  1. Fuel pump/filter replacement?
    By Cadeez in forum Maintenance
    Last Post: 08-25-2011, 04:44 PM
  2. Replies: 5
    Last Post: 07-24-2011, 01:59 PM
  3. Part fell off while changing fuel filter!
    By cparker in forum Maintenance
    Last Post: 06-12-2011, 06:05 PM
  4. p0171 and p0174 with aem cai
    By baileau in forum Mechanical | Troubleshooting
    Last Post: 03-06-2011, 03:35 PM
