Kyle - Wisconsin Crew - 2001 BMW M3
Supersprint Headers/Section 2 - Eisenmann Muffler - aFe Stage 2 Intake -
Bilstien PSS9 Coilovers - VMR V710 (Gunmetal Powdercoat) - UUC EVO Short Shifter - ZHP Shift Knob
Kyle, no worries. We're all passionate about our cars. We're also passionate about having answers.
Good luck getting to the bottom of things.
Have my appointment set for next Friday with Seth @ JB Eurotech. They do great work and Seth is a really good guy!
Good. I'm sure you'll follow up with us.
The more I look at the video, the more I am thinking there is not much wrong.
You hit 80 mph in ~14 sec and 95 mph in ~18 sec, is that bad?
Also, it is normal for RPM to dip when you switch to a higher gear, that's the whole idea (and the reason you have 6 gears).
Nevertheless, I find this thread interesting and a good learning experience.
I am also curious if the dual mass flywheel might not be involved: See symptoms here
Not sure I understand this video.
Our flywheels are designed this way
The spring movement is exaggerated on that video. Even if the springs collapsed inside the blocks (mechanical stops) would keep the flywheel from free spinning and would instantly meet themselves and try to break the tires loose as a result instead of just slipping and then grabbing.
The springs collapse anyway when you dump the clutch and or shifting properly--That is by design.
Thanks for the info VA. So not likely that the flywheel is involved in OP's problem (if he does have a problem).
Inquisitive minds want to know!
