Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 62
    It allows the bushing to have less pressure on it (especially lowered cars), alignment should be as close to stock as they can get it, and offset bushings help with this, especially if you don't have the pricey adjustable camber plates.
    Apr 2011
    Bay Area, Cali
    Quote Originally Posted by nike001 View Post
    Bump. Considering Z4M bushings instead of going poly..
    I'm not a fan on poly suspension on a DD. A dd should be comfortable and quiet, I would go with this route IMO.
    I wonder if it will work with regular old non-M/non-ZHP E46 control arms? I think it would since ZHP and non ZHP CAB's are the same..
    Philadelphia
    Quote Originally Posted by Johal E32 View Post
    Should. Only difference between ZHP and non ZHP control arms is the inner ball joint (or maybe it was outer?) -- the wishbones themselves are the same
    Also you can get the bushings pre-pressed in the housings too:
    31107836862
    31107836863
    Might be best to go that route since pressing out the hydraulic bushing is a bit of a pain
    Sep 2011
    San Francisco, CA
    I remember a Technician saying the M3 and the Z4M bushings were offset. Do you know how much caster is changed from the original ZHP setup?
    nike001 Guest
    I would think an alignment would be needed before and after to show the caster changes. I don't think anyone has done so yet..
    nike001 Guest
    Just ordered the z4m bushings for a couple bucks under $50.. Should be here tomorrow and installed by Saturday
    Knoxville, TN
    ^Ballin'. Out. Of. Control.
    nike001 Guest
    Whoops, they ended up being $38.34. I heart employee prices
    Apr 2011
    Dallas
    Pre-pressed into new brackets or just the naked bushings?
    Philadelphia
    Quote Originally Posted by derbo View Post
    M3 bushings are centered. But I think our control arms give a similar effect as an offset bushing
  1. Polyeurethane vs Rubber Control Arm Bushings
    By Gatsby in forum Suspension
    Last Post: 08-26-2014, 10:16 AM
  2. FS: Control Arm Bushings and Trans Mount Bushings
    By Vas in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 04-25-2013, 06:20 PM
  3. Is this an offset issue?
    By Strider in forum Wheels
    Last Post: 05-27-2012, 05:41 PM
  4. Replies: 2
    Last Post: 06-23-2011, 03:17 AM
  5. Offset for 19's
    By Speedracer in forum Wheels
    Last Post: 05-26-2011, 05:26 AM
Tags for this Thread
