No, this is Ludacris
This seems to be a good place to post this question.
I'm currently running stock wheel/tire set up on my Sedan. I'm lowered on HSD coilovers and I have slight rubbing against the springs in the front WITH a 5mm spacer. Now I'm considering running a 10mm in the front, but how big of a spacer can I go in the back without rubbing/rolling fenders. I'm also maxed out in the rear, no collars for the spring, and the strut is at its lowest setting.
I just don't want the front wheels to be super aggressive while the rears are sunken in.
We need...
Take a ruler and measure at top of fender. How much room do you have?
I bet you could squeek 5-10mm spacer in back there....but I don't have 135's.....so I'm guessing.
On my winter setup I run a 10mm spacer in front to clear the coilovers and stock offset in back.
You could also try moving your 5mm spacers to the rear as a place to start.
Here's mine with 10mm in front.
I was running a 15mm in the rear with Style 135 in the rear. I rolled the back fenders but seem to rub the left side rear. I switched to a 12mm rear and the problem went away.
First set up was 20mm in the front (no rolling or any problems with the front)
15mm in the rear slight rub nothing that would pop a tire or anything just bothered me to hear it
Second set up
moved 15mm to the front
12mm in the rear no problem with rub
This was with style 135s.
the first set up looked great just had the slight rub. I did this due to wheel rubbing suspension. The second whil not as aggressive still looked really good with no rub.
I had my fenders rolled in the rear.
I have BBS CH replicas 18x9 et 37 in the rear and going to put on 5mm to push them out some more to have the flush look (in the front too).
Depending on your coilovers you need to get the et to 25 (around) in order to eliminate the tire rubbing the spring.
You guys make this stuff way too technical and way too hard on yourselves. I will provide a step by step of the proper procedure.
1. Drop it.
2. Poke it.
3. Stretch it.
4. Roll it.
Done.
and always remember, "It sucks to roll hard."
Haha, Stanceworks motto! I will be going crazy once I save money for the wheels I want, but until then OEM will have to do.
I have about 1/2inch clearance between the bottom of the fender & the top of the tire in the front. The rears are tucking, but the space between the side wall of the tire and the edge of the lip in the rear fender is also about 1/2inch.
OK......so........you can probably fit a 10-12 up front....and maybe a 7-10 in the rear, since you're tucked.
Which in the world of fitment means you can fit 15mm up front and 20mm in the rear, make some camber adjustments, get a tire that has a slight stretch on it, roll your fenders (possibly a slight pull) and then lower your car another inch and be good.
My specs were
3" drop
19x 9.5 offset 32 wheels
235/35/19s
My car was flush and had a great stance. You couldnt get a babys finger between tire and the wheel well and the well rested 5mm above the rim. This required full dampening on my coils to prevent damage to my wheels on compression.
Point being, just because a book says that something won't fit, or the numbers don't crunch a certain way doesn't mean that it wont. If you want to roll hard, you have to get in there and problem solve to get the fitment you want.
and in regards to the Stanceworks motto, it is actually "Low is a lifestyle".
